Question about Miele S251i Plus Bagged Canister Vacuum
My Miele wand is jammed. How should I fix it
What is the best way to ease the segments apart?
Dyson dc43
I had no suction with the head but has lots with the wand. Found out the problem. Take the head off and underneath the motor you can see a small segment of hose that pivots from wand to head depending on what position its in. Mine got jammed with a thin piece of wood that prevented it from pivoting to the head. Easy fix.
Mar 07, 2013 | Dyson Vacuums
The telescopic wand on my Miele S5281 keeps collapsing, how can I fix it so it locks in place.
Hi There,
You can get a button repair kit and it should fix your problem which is normally a loose spring. In Australia VacuumSpot sell these over the net.
Jun 12, 2012 | Miele S5281 Callisto Bagged Canister...
I have an old Miele canister vacuum and I do not know how to disassemble the hose to check for a clog. I think it sucked up a nerf ball the size of a ping pong ball. I changed the bag but it did isn't...
Hi Emily: If you have the model number for your machine you may be able to find your manual on the Miele website. Check here for older models Here for newer models.
In trying to isolate the clog it would be best to disassemble the wand and hose to more easily isolate the problem. If the problem is a ball it is quite likely lodged at the first elbow
Generally, to detach the suction hose from the canister press the release buttons at the sides of the elbow and lift the hose from the socket.
To release the handpiece from the wand, press the locking button and pull the handpiece away from the wand. Similarly if your unit has a floorbrush this can be detached by pressing the locking button and pulling the wand out of the floor brush.
You may need to insert a wire from the canister end to push out the clog or ball opposite to the direction it was sucked in.
If these directions are not helpful and you cannot locate the manual for your model, please reply with your model number as I may be able to locate it from other sources.
Thank you for using FixYa!
Feb 13, 2012 | Miele Vacuums
The wand that connects to the power head at the powerhead connection broke(sheared off) fine crack
Unfortunatley the Wand for your Miele is sold as an entirely assembly only. Miele does not sell pieces of this wand separately. In order to fix your wand you'll need to purchase a new wand assembly complete.
The wand on your Miele is the Miele SET210 Wand. Here's a link if you need to purchase one;
http://www.govacuum.com/miele-172.html
I would probably guess that your wand broke off right at the bottom where it connects into the power nozzle. Unfortunately this is the weakest part of the wand as you can probably see. The wand narrows into a thinner plastic here, and I've seen a few wands crack off right on the bottom part.
Please feel free to request a repair clarification if you have any questions about how to repair your vacuum.
If you found this helpful, please be sure to rate it by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele s558 Silver Moon Vacuum
Meile SEB 213 powerbrush cuts out
Your problem is either in the wand, assuming you have the telescopic dark grey electric wand. The only other thing it could be is the hose, once again, assuming you have the electric hose with either the rocker switch that shuts down the power brush, or the deluxe hose, with the electronic suction control, as well as the brush shut off. Miele wands and hoses are notorious for causing power brushes to cut off. If your Miele is under two years old, I would suggest taking it to a autherized Miele service center, and see what, if any, warranty you have left, and have it checked out. Let me know how you make out.
Jan 14, 2009 | Miele SEB 213-2 Vacuum
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident(I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761462
Generic problem for all Vacuums
Posted by greenvanilla on Jul 09, 2008
I'm using Miele Medivac vacuum and I just sucked in a small plastic eye drop container by accident (I sometimes take off the brush part to **** in 'small enough' articles). And it is jammed in the part where the plastic hose connector bends. I think I can take it out if I can just disconnect the long necked plastic hose connector that connects the metal wand part and the hose part. Is it designed to be disconnected or should I not even try it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The long necked plastic hose connector is made to be replaced because they do brake upon occasion and the part is made to come apart. If you need assistance please contact your local vacuum cleaner dealer or to contact the Miele factory to get a owner’s manual to check the trouble shooting guide and or a schematic of the breakdown of how to un-install the
long necked plastic hose connector or gooseneck of which some people call it. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://miele.com/
Customer Service, Repairs, Parts 1-888-785-2828
Mailing address listed below:
Miele, Inc
9 Independence Way
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Miele S251i Plus Bagged Canister Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
