Question about Pool & Spa
Jandy legacy lrz
Shorted air sensor
thepool
  • 78 Answers
SOURCE: jandy AE.TI AE3000T .263
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Posted on Apr 22, 2010
  • 256 Answers
SOURCE: jandy legacy pool heater brand new igitor doesnt
Good day. Some of the gas heaters have a battery powered ignitor. Please check if batteries are installed, and if so, is there sufficient power from the batteries (have the run down). Hope this helps
Posted on Jun 21, 2011
  • 910 Answers
SOURCE: Good afternoon. I have a Jandy Legacy 125KBtu that
The link below is the manual for your heater.
http://www.hydropool.com/downloads/Jandy/Jandy_Legacy_Pool_Heater.pdf
You need to open the unit and check the connections to the Universal Controller Power Interface PCB as shown on Page 42.
Are their any connections on the Terminals marked Coil/Air Temp and Fan/Louvre?
Are these connections secure and free from damage and corrosion?
Posted on Jul 14, 2011
davidspra65638
  • 8673 Answers
bad PCB board
Posted on Jan 20, 2018
davidspra65638
  • 8673 Answers
check inside by power supply if wiring 120 volt need to separate wires with nut on them see inside of front panel for instructions
Why is the flame on but water not heating
check gas pressure if correct check heat rise you might need to slow water flow down
Jun 17, 2014 | Jandy Legacy Natural Gas Pilot Light Pool...
Legacy Model Lrz heater code Shorted H20 Sensor
replace temp sensor it mounted on front of right side header the one with the plastic nut in it with 2 black wires
Aug 05, 2013 | Jandy Pool & Spa
Zodiac Jandy Legacy LRZ Pool Heater pilot wont light only used 1 season
check safety circuit possible fusible link open if bad check gas pressure if too low will run too hot and soot up make sure to clean outside of heat exchange so heat can go through top not front
May 27, 2012 | Zodiac Jandy Legacy LRZ 175K Commercial...
How to winterize ? i have the jandy lrz model 125000 natural gas and what to know how to close down and winterize
turn off gas valve and blow water out with air then with RV antifreeze when you see antifreeze coming out its good see you tube video on pool closing
Oct 27, 2010 | Jandy Legacy LRZ 125000 BTU Millivolt...
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
