Indesit washing machine IWB 6123
Conditioner holder still full after wash is complete
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
  • 209 Answers
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
Posted on Sep 09, 2007
gittos73
  • 244 Answers
SOURCE: The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Posted on Nov 17, 2008
SOURCE: all lights flash on indesit washing machine soon after switch on
Indesit washing machine lights come on briefly when awitched on at mains and then no power
Posted on Apr 19, 2010
SOURCE: f-02 fault code on indesit we16 washing machine
For what it is worth my WE16 often stops with an F-02 display within 3 minutes of starting, but only in summer months. Powering off and restarting usually cures it, and it will then go on to run several loads without problem. I keep the machine in my cellar boiler room, and attribute the problem to high humidity when the boiler is not running. Changing the PCB does not cure the problem, nor does protecting it against humidity (eg poly bad and silica gel). I conclude that moisture getting somewhere unexpected (tacho perhaps?) can cause this error.
Posted on Jun 12, 2010
How to turn on child lock wash machine indesit innex xwsc 61251 ?
The Innex XWSC 61251 does not have a Child Lock or Control Panel Lock feature. The only way to completely disable the washer buttons would be to unplug the unit. The manual is available on the product page: http://www.indesit.co.uk/appliances_i/Washing_Machine_XWSC_61251_W/pid_F085657UK/40.do . The direct link to the manual is http://www.indesit.co.uk/indesit/_pdf/manuals/19512007300_GB.pdf .
I hope this helps.
May 31, 2016 | Indesit Washing Machines
Indesit widxl 126 washing machine fabric conditioner compartment blocked
Indesit widxl 126 washing machine fabric conditioner compartment blocked.
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Washing Machines
Hiya i have a indisit ( silver ) evolution washing machine, and recently all the washing power has not been goin away ???? what i sthe cause of this ?? so i recently bought some liquid laindry to try that...
My daughter has a cold fill only Indesit so I can tell you without sending my other guidance notes!
1 is for pre-wash (LHS), 2 is main wash (middle and bigger) and you are right with 3; that's for the conditioner.
I would suggest giving the whole detergent dispenser a good clean. Here are my complete, general, pre-typed (!) guidance notes. Note the second way to remove the dispenser in particular---->
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this hasn't helped I suggest you pull the dispenser a little way out, start a main wash and see if water pours into the main wash tray as it should or if it just trickles in. If it does the latter there is a problem with the water inlet valve- I presume it's a cold fill only? This requires a service call ;-0(
Good luck,
John C
Cheers,
John C
Mar 17, 2011 | Indesit Washing Machines
The fabric conditioner container in the washing machine is always full of water after a wash
What follows is my 'standard' reply document for this type of problem, slightly modified for your problem then copied and pasted!
Although you do not say which model it is, this is a common problem with many machines.
I suspect that it is 'gunge' in the conditioner/softener tray which is causing water to remain so it needs a thorough clean!
  • push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (for most Indesit models) or
It will normally have some sort of cover on it which you must remove to expose the little stuck up pipe/tube. This is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
I hope this is your problem and solution!
Good luck,
John C
Feb 13, 2011 | Indesit Washing Machines
Indesit IWB 5123 Washer Which program ends with the washing left in the final rinse water until spin cycle is selected
push in yourrince hold/or crease gaurd button if you have one. normall wollen cycles will stop.
Feb 16, 2010 | Indesit W 123 Front Load Washer
Nov 15, 2008 | Washing Machines
Indesit washer w123
take soap drawer out and clean it
Aug 28, 2008 | Indesit W 123 Front Load Washer
Washing machine drawer
Jul 14, 2008 | Indesit W 123 Front Load Washer
Indesit washeing machine
Karen, that was nice.........
May 31, 2008 | Indesit W 123 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
