Question about Dell E771p 17" CRT Monitor
Monitor does not display after few seconds
When i start my monitor ,it displays for few seconds and then the screen vanishes upon tapping the screen reappears it is a continues process and also the display is not proper
CompuGuy44
  • 432 Answers
SOURCE: Menu and OSD Problem
Yep. Sounds like one of the buttons is shorting out and causing the icon to pop up. You can try canned air. If your good with tools, See if you can take the bezal(the plastic part around the screen) apart to clean the button contacts.
Posted on Jun 22, 2007
  • 36 Answers
SOURCE: monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Posted on Jul 12, 2008
ici1011
SOURCE: Dell 1703FP monitor issue
reduce the hardware acceleration on it. I resolved it by reducing acceleration and changing my screen size. It works. I wanted higher resolution but it doesn't seem to be possible for some reason.
Good luck.
Posted on Jun 20, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
budmrtn
  • 11361 Answers
SOURCE: After a few seconds of being turned the display
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd.: www.lcdrepair.us
Posted on Jun 21, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Hello my Dell inspiron has a white screen upon start up but once it's on the login screen it's fine after that is it the cable coming loose or a bad video chip plz help?
Try connecting an externalmonitor to the Dell Inspiron and see if the white screen is also presenton the monitor. If the monitor display is fine, then your laptop's LCD displaypanel is defective. If the monitor also displays the white screen, then yourproblem is with either the video card or motherboard located inside yourlaptop. Also try booting the computer in safe mode by tapping the key when you turn it on. If it works that way you might have a video software driver issue.
Aug 17, 2011 | Dell Inspiron N5030 Notebook PC
HOW TO ADJUST THE BRIGHTNESS AND SO ON.
Press the OSD button to show the On Screen Display.
Press the UP/DOWN or LEFT/RIGHT buttons to move through the various menu-items.
When you get to the correct item, press OK to select that item.
Then, use UP/DOWN or LEFT/RIGHT buttons to adjust.
Press OK to "accept" the adjustments.
Wait a few seconds, and the OSD will vanish.
Jul 30, 2010 | Acer AL1916W 19" LCD Monitor
Display screen not centered
Press the OSD ("On Screen Display") button on the bottom-front of the monitor.
Choose the "horizontal position".
Adjust that control to move the image to the centre.
Just wait, and the OSD will vanish.
Jun 15, 2010 | Dell E207WFP LCD Monitor
Adjust screen brightness
Press the OSD ("On Screen Display") button on the bottom-front of the monitor. Use the other nearby buttons to "navigate" through all the settings, to select "Brightness", and to move the level UP/DOWN.
Wait a few seconds, and the OSD will vanish, by itself.
May 13, 2010 | LG Flatron L1750S 17" LCD Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Hello Sir, I am using DELL E173FP LCD monitor. My CPU absolutely fine I see initially booting thing on my monitor display then it gets black. I can hear starting sound of Windows XP, that too is fine. When...
You might need to change the screen refresh rate. Go do Control Panel> Display> Setting> Advance, choose 60 Hz. In order to make your Monitor able to display, restart the PC, press F8 on the keyboard frequently upon splashing ( 1 or 2 seconds after PC restarts). Select enable VGA mode by pressing up arrow of the keyboard> press enter. The display should look bigger, then you can start adjusting the screen refresh rate to 60 Hz
Apr 09, 2010 | Dell E173FP 17" LCD Monitor
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
Dell E771p 17" CRT Monitor Logo
13 people viewed this question
Alun Cox
