Question about Garden
Fuel lines for HG55-12 part NO. 530069599...
I NEED FUEL LINES
boscia
  • 163 Answers
SOURCE: weed trimmer
no, the overflow line does not need to be submerged. first make sure that the hose connections are tight and the "O" ring or gasket inside the gas cap is not damaged or missing. when replacing both lines at once, its easy to get them mixed up, so make sure they're not. remove the carbuerator and inspect the gasket; it should be soft and flexible, if its hard or brittle it needs replaced. it doesn't take much to clog it, so spray carb cleaner, available at local auto parts store, inside the fuel rails and blow out with compressed air. there might also be a pin hole or bad seal in the primer bulb and need to be replaced.
Posted on Nov 28, 2008
  • 3600 Answers
SOURCE: Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Posted on Jun 21, 2009
SOURCE: I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf, I had to buy fuel lines last week. I called the local sears parts store, and gave them the model number. They had a rather generic bag with the correct diameter lines. Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off. Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb? Thanx.
Posted on Jun 22, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
  • 3 Answers
SOURCE: need a diagram to route fuel lines on a carb
my polaris outlaw 500 sarted cuting out last ride could not ecerate past 1/4 throtle and was back fireing so went to fix and wont run at all i have spark, plug is wet, changed fuel, seems to have compresion, when it turns over it tries to fire at times more like a hickup almost stops the sarter and a puff of smoke out the carb. im about to tare it down any ideas whats wrong ? bike was hard to start but ran ran perfect killed raptors with ease. bike was bored and built by some shop before i owned using ktm sleave and piston ? motor says nicols 520. didt over heat or make noises. have tried cleaning carb, jeting no luck please help
Posted on Jul 14, 2009
Fuel lines from the fuel filter
oh boy.... now you need a flare kit and redo the ends of the lines going to a flare nut 9/16 and then use a old fuel filter from a 1970 chev or something . im guessing you had the clip on lines where you needed a special tool to unlock the lines .
Nov 07, 2013 | Lexus ES 300 Cars & Trucks
Remove fuel lines from fuel pump housing
You may need a fuel line tool that compresses a spring in the collar. You can get them at any auto store..
Apr 28, 2013 | Cars & Trucks
Replace fuel lines on model no. 358.797931
Hi.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash, broken lines,etc. from the fuel tank.
After you have all the trash,fuel lines and filter removed.
You will trim the end that goes into the fuel tank to a point.You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers push the fuel line and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank .
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Hook up the fuel lines to the carburator and you should be good to go
Please take time to rate me
Bud
Apr 21, 2013 | Garden
How to change fuel lines
There should be only 2 fuel lines and a vent line coming out of the tank. The vent line is for fumes that are routed to the charcoal canister-part of the evaporative emissions system, and the two fuel lines are the main feed line to the filter and then on to the engine, and the other gas line is the return line from the engine back to the gas tank. All fuel injected systems have a feed line and a return line. The return line is for fuel not used but sent back to the tank by the fuel pressure regulator.
Nowadays, rather than replace metal lines, shops can use the plastic fuel lines (they don't rot!) and special connectors to fit new fuel lines. YouTube has lots of videos on replacing fuel lines.
Apr 23, 2017 | 2004 Buick Rendezvous
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
Sep 24, 2011 | Garden
I need instructions on replacing the line on our Remington Lawn Trimmer
Hi pwdw71...
You will need to go to the lawnmower/weedeater parts house with a sample of both lines to be able to replace the lines with the right size fuel lines.
Also check/clean/replace the fuel filter inside of the tank.
Also take your Mfg. and model number with you.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru and primed the carburetor by the primer bulb.
You will insert the big line into the fuel tank far enough to be able to install the fuel filter.
Free Answer...Please take time to rate me
Jul 04, 2011 | Electric Garden
Gas hose broke inside tank on a TB70SS trimmer
At this point, I suggest you drain the fuel. Pull all fuel lines off (a little drawing of where they each go will come in handy). Then you will need to get a new fuel filter and new fuel lines. What happened is quite common as the fuel lines eventually deteriorate over time. New "Tygon" type lines are available at small engine repair shops and even Home Depot has fuel line kits (including the fuel filter) for Ryobi and Homelite trimmers. If you need installation instructions for all your new fuel lines, post back. There is plenty of help available.
May 16, 2011 | Garden
My Toyota Sienna keeps stallling
If the car stalling then the owner of the car should check on the fuel pump assembly. prepare the tools and equipment in servicing the fuel pump,the fuel lines and the fuel filters.In the fuel pump you have to locate the fuel pump,disconnect fuel lines from the fuel pump,remove fuel pump from the engine,dis-assemble fuel pump, check the diaphram for defect , replace defective parts,assemble and install the fuel pump.
In checking the fuel lines : prepare the tools or equipment in servicing the fuel lines .So that the fuel will flow freely and no abstraction within the fuel lines.locate the the fuel lines ,visual inspection on dual line for leakage, disconnect lines at fuel pump and fuel tank .use compress air to remove sediment on fuel lines,re-install fuel lines to the unit.
the fuel filters :prepare the equipment or tools in checking the fuel filters that is going to be used.So that when fuel filters is removed ,no fuel will spill on the vehicle and no parts are lost or broken.Locate fuel filter,disconnect lines at fuel filter ,observe safety practices ,If the fuel filter is dirty then you have to clean it but if it is worn out and not anymore to be used then install new fuel filter.
Sep 24, 2009 | 2008 Toyota Sienna
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Had fuel pump replaced 3 months ago brother cut orig. fuel lines
lines to fuel pump are preformed plastic and break if tank is lowered wrong only complete lines can be perch est rubber fuel hoses kink and choke off fuel pressure due to sharp bends and tight space to re-pare just ends you need metal tubing and tubing bender short fuel lines and clamps also skill and dedication
Mar 19, 2009 | 1997 Chevrolet Tahoe
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
