Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Sounds when connect XBOX 360 to HD port
Hi I connected my red, green, blue wires to the black adaptor and put in EXTNS 4 port fine. Picture is great. But there is only one hole for the sound in this port, and all I then have is a yellow, white and red cable which I can only put in at the bottom in EXTN 3 so if I run the XBOX 360 on EXTN 4 on the TV I cannot get any sound? Is there another cable I am missing or something. Thanks for any help C
  • 6 more comments
  • Curtis Fogler
    Curtis Fogler Nov 12, 2007
    After hooking up my XBOX 360 Elite everything was great, until I switched back to watching to watching cable. At that point I had no sound. I switched back too the HDMI connection , still no sound. Tried my dvd player, still no sound. I then reset the TV back too manufactured setting and it was fine. The tv has done this several times and I have no idea how too fix this, I even went ontoo sharps websight and checked for downloads and updates in firmware, still nothing.......Please help!!!!!
  • Dazmondo Dec 28, 2007
    I have a Sharp LC 32BT8EA Aquos LCD TV and have the Red, Green and Blue jacks plugged into the EXT 4 multipin plug supplied with the 360 and lo and behold, found I had no sound. I then connected the red and white into the EXT3 however still have no sound as you need to have the channel set to EXT 4 to get a picture. I contacted the Sharp helpline and found it to be no use whatsoever. I have also tried altering the settings on both the Xbox and the TV but to no avail. Can anyone help?
  • Anonymous Mar 19, 2008
    no sound when connecting to ext 4 using cables as there is no port for red and white plugs
  • gaffer99 Jun 19, 2008
  • JammieD Jan 07, 2009
    Yeah my sound will not work when i play in HD on my xbox. :(
    It works when i use the scart slot, but when i put the RGB slot on my tv, the Hd works fine but i do not get any sound. I have tried going to the xbox dashboard and changing the settings, but it did not work. :(
    Do i need a new cable or somthing? or a new sound system?
  • Anonymous Apr 09, 2009
    same thing. No sound in HD. Fix it tho. just put the other red and white(audio) cords next to the HD ones and bam!!! sound
  • Anonymous May 10, 2009
    I have the same problem. Plugged green, blue and red HD cables into HD sockets, the red & white into sound leaving the yellow band unplugged. No sound.
    Frustrating. Picture is great though.
  • jasonwrighti May 15, 2009
    i have the same problem there is 3 ports for the hd but none for the sound connection i tired to do the sound threw the scart lead but still no sound anyone know what to do
    Problem Solver:
  • 19 Answers
You need to run the white & the red to the aud. input
Posted on Sep 16, 2007
You dont have to do anything with the red and yellow cable all you need is the green blue and red blupped into the back and the white cable plugged in next to them i just figured it out.
Posted on Oct 11, 2008
There are 6 connections all together and the only 1 that yo dont use is the yellow as the red and white are for sound. i solve this problem by wiring the sound through my stereo
Posted on Mar 02, 2008
Next to Ext 4 on the TV there is a mini jack socket saying L/R. You need to buy an adapter cable ( Mine was £4.99 from Maplin) which is mini jack to red and white female RC sockets. Simply plug the mini jack into the tv and the red and white from your xbox hd lead into the other end and bingo!
The yellow plug becomes irrelevant so just leave it hang.
Posted on Nov 14, 2008
I have no rgb port to put the cables into to make it hd and have no hdmi port how do i get my hd to work on the television my tele is hd ready
i bought a dvi to hdmi cable and i have a pic but no sound any advice would be warmly welcome
Posted on Nov 21, 2008
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
I just need to see a visual connection of xbox 360 to bacig flat screen tv.Eight now i am not getting a picture.Ihave regular x box hooked up and iam getting a picture for that.
First check the AV audio/video wires to determine if you have SD or HD wires. If you have 3 plugs (red, white, and yellow) then you will get standard definition (SD). If there is 6 wires (2 red, white, yellow, blue, and green) then you can connect High Definition (HD) and you can also connect SD as well. Now what you need to look @ if you have the wires with 6 ends (component HD AV wire), is on the part where you plug into the back of the Xbox 360, there is a switch on the box that is on the wire. It should say "TV" and "HDTV". If you have the component wires hooked up (5 wires) then select "HDTV" if you have only the 3 wires (red white yellow) for SD hooked up switch it to "TV". That is the first thing to check. The next thing to check is the way the wires are hooked up. If connecting HD, you very easily could've mixed up the 2 red wires, 1 is video and the other is audio. The way to determine which is video and which is audio is, for video, the actual plug itself is gray with a stripe of color which indicates where it goes on your tv, the audio plugs are solid white or red. And remember that the yellow plug is not used for HD setup. If you have a Xbox 360 that has the HDMI (High Definition Multimedia Interface) input, then I would recommend using that to hook up your console. With the HDMI its only 1 wire to hook up and is extemely easy to set up. The HDMI wire transfers audio and video all in 1. There is only spot it can fit into, and its located right next to where you plug in the AV wire on the console. To me, the HDMI is "cleaner" looking b/c its only 1 wire.
Feb 27, 2010 | Video Game Consoles & Games
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
I think the video cable for my xbox is messed up. Why does it keep showing up these little circle things? Whenever I turn on my xbox it doesn't come up anything but a black screen with little circles...
NOT HD: Make sure red goes to red, white on white, and yellow on yellow, also make sure the switch that is on the xbox wire plug says TV not HD.
HD TV: Make sure red on red, white on white, yellow on yellow, blue on blue, green on green, etc. Also make sure the switch that is on the xbox wire plug says HD not TC
Oct 18, 2009 | Microsoft Xbox 360 Console
If the hd inputs on my tv are red and white and the hd plugs on xbox are red blue and green,what goes where?
match the colored wires from your HD plugs to the ports on your tv then take th red and white audio wires and plug the into the red and white audio ports.
Oct 15, 2009 | Microsoft Xbox 360 Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
My xbox colors are messed up
How is the 360 connected to the TV? This sounds like your component cables are attached wrong. make sure red, green, and blue are connected to the corresponding jacks.
May 03, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 won't work in hd
is ur tv has just red white and yellow then ur tv is not hd trust me
Oct 26, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
5,406 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
