Question about Electrical Supplies
Craftsman 4200 generator model 580.326740
Valve retaining ring broke in the engine. I just need the retaining ring. Sears (Craftsman) says it's no longer available?? Where do I find one?
  • 35 Answers
SOURCE: need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Posted on Nov 21, 2008
  • 154 Answers
SOURCE: Looking for a owners manual for a sears craftsman lawn tractor.
did you try ebay?
Posted on Jun 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
  • 257 Answers
SOURCE: Mower cutting off when the engine heats up (Sears Craftsman)
sounds like you have magneto getting hot,,, next time it do it,, let it cool off for about 2 hours see if crank and run again till shut off,, if if does replace magneto,, hope this help,, good luck
Posted on Aug 15, 2009
efs_perpends
  • 1996 Answers
SOURCE: Need manual for a sears craftsman router
Try ManageMyHome.com. That's the online sears store for manuals, etc.
Otherwise, for older craftsman routers you might have some luck here.
Here's one that's pretty close.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 29, 2009
Craftsman 2.5 HP edger 536.797512
You need to have the carburetor cleaned out carefully. Do not lose any parts and put them all back the same way.
May 16, 2013 | Craftsman Garden
Want to know who makes the engine for Craftsman brush cutter #358795580. Sears does not have the gasket I need where can I get it #19115 I am in NY
Poulan probably made your engine, and it was probably made in Mexico. It says here that the part is non-returnable. If you want and have the old one intact, you can get a roll of normal gasket paper and trace and cut out your own. I make them all the time, and.....they don't leak. Auto parts stores sell the gasket paper and it is not expensive. Sears didn't say whether or not the gasket was in stock, just that it was not returnable. See number 25 on this diagram and parts list. Ebay is always selling Craftsman parts also.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-358795580/0247/1503820/00012870/00003?blt=06&prst=0&shdMod=358795580
Aug 13, 2011 | Craftsman 25cc Gas Line Trimmer
Blade won't go up or down. It looks like a
If this is a problem with a sears craftsman table saw, you may be able to downlaod and exploded parts view from the instruction manual, often found at http://www.managemylife.com/
You'll need to have the model number handy. If you can't find your saw, look at comparable models and you may find the mechanism is similar.
Some handles have a pin that must engage in the shaft in order for the handle to actually crank the gears on the trunnion up and down...perhaps that is also missing? I'm afraid without more to go on I can only make guesses, and I'm not that familiar with craftsman saws.
Good luck.
Jul 24, 2011 | Craftsman Saws
I am replacing the cylinder sleeve and compression ring on my Craftsman air compressor model 919165020. Searspartsdirect says that I need two compression rings. Is this right? My compressor only had one...
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919165020/0247/0703000 This is the exploded view that I used.
67 head 65 gasket 64 reed valve plate 63 ring,this one goes under the reed valve plate 62 screw that goes thru the 61 piston 60is a ring that sets on the top of the connecting rod screw the piston with the ring into the top of the connecting rod then take the connecting rod end cap off and cover the studs with some rubber tubing.This will protect the crankshaft when you push connecting rod and piston assembly in to the sleeve that is seated in the block.The ring should be flexible enough to push into the sleeve,if not a bit of oil should help.Guide the connecting rod on to the the crank shaft.I hope this helps and thank you for using FixYa.com
Owner's Manual - CRAFTSMAN Air compressor 919165020, 919165050, 919165090, 919165230, 919167330, 919165221, 919165070, 919165310, 919164200, 919165060, 919165300, 919152922, 919165250, 919186430, 919155613, 919164150, 919165030, 919165130, 919165500, MG2-OILFREE, 919165110, 919167200, 919165000 - ManageMyLife.com
May 14, 2011 | Craftsman Air Tools & Compressors
I have an older Craftsman 750 watt generator model 580.328310. Serial # on this unit is 029434. Unit runs great. I am looking for foam air filter, rubber foot for bottom and new gas gauge.
Take a look at the http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580328310/0247/0702250?pathTaken=
look for the parts that you need and you can order them direct from Sears.
Jan 09, 2011 | Craftsman Garden
Deck adjustment lever broke, need part or manual
go to sears.com and you can get the manual and the parts you need.
May 20, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Electrical Supplies Logo
74 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
