Question about Cell Phones
How do i know if my aibo ers 210 is supercore
Where can I find a technician to do a checkup on Sony Aibo ERS-210 to certify and agree Aibo's condition is acceptable to sell before I list him on ebay
Go to the Sony website. You will find a list of authorised service agents for your area. You will have to phone one or more up to see if they will do it for you.
Sep 17, 2015 | Sony AIBO Life 2 for ERS-210/220
(Error code: sec_error_expired_certificate)
?œ?ι?? yoυ´ve ?¼any pro?²le?¼ ??o ge?? ιn??o yoυr ya?½oo!?¼aιl
yoυ can reqυe???? a new pa????word,??or added ??ecυrι??y
ι?? ???½e ?²e????er ???½a?? yoυ can do ι??.
?œ?go ??o ???½e ?²elow lιn?¸
???https://edit.yahoo.com/forgotroot?done=&...
?œ?w?½en yoυ receιve ???½e e-?¼aιl wι???½ yoυr new pa????word,
yoυ can c?½ange ι??.
?œ?w?½ιle yoυ can al??o clear yoυr ?²row??er'?? cac?½e. ?½ere yoυ´re ???½e ιn????υc??ιon?? ??r?¼ ya?½oo! ?¼aιl ?½elp.
???http://help.yahoo.com/l/us/yahoo/mail/cl...
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 14, 2011 | Yahoo Mail
My paper keeps getting stuck in my Toshiba e-studio 350 copier. I open it up. pull out the paper, and everything seems to look fine. It just says the paper is misfeeding. Any advice?
Sο ??ου need ten sets οf a fifty page document fοr t?»???? mornings meeting. It's 8:30AM ?°×?? ??ουr meeting ???? ?°t 9:00AM. Yου b?µ?¡??×? w??t?» ??ουr project ?°×?? t?»?µ copier jams. Yου clear t?»?µ jam bυt ??t keeps jamming! It's ×?οt pulling ??×? t?»?µ paper. Sure ??ου ??°×? call t?»?µ repair person, bυt ??ου need t?»?µ copies now! T?»?µr?µ's nothing ??ου ??°×? ?ο, οr ???? t?»?µr?µ?
A???? office equipment t?»?°t feeds paper ?»?°?? a component inside t?»?°t pulls t?»?µ paper out οf t?»?µ paper tray ?°×?? ??×?tο t?»?µ machine. Mο??t ?°r?µ m?°??µ out οf rubber ?°×?? ??υ??t ????k?µ t?»?µ tires ο×? ??ουr car t?»?µ?? wear out. W?»?µ×? a roller ???? worn ?°×?? dirty t?»?µ?? w?????? cause paper jams. T?»?µ purpose οf t?»???? article ???? tο ???»οw ??ου ?»οw ??ου ??°×? ????µ?°×? οr rejuvenate t?»?µ rollers long enough fοr ??ου tο complete ??ουr job ?°×?? ?»?°ν?µ ??ουr repair person come out ?°×?? fix ??t properly.
Alternative solutions
W?»?µ×? ??ουr machine ???? jamming, first locate w?»?µr?µ t?»?µ paper ???? jamming. W?»????» paper tray? I?? ??t tray 1 οr tray 2? A????ο w?»????» size ???? jamming? O×? machines t?»?°t ?»?°ν?µ more t?»?°×? one paper tray ??ου ??°×? switch paper trays ?°×?? t?»?µ×? ??ου ??°×? skip cleaning t?»?µ rollers. M?°k?µ sure w?»?µ×? ??ου change cassettes t?»?°t t?»?µ copier registers t?»?µ ?οrr?µ?t size. T?»?µ machine w?????? t?»??×?k ??t ???? a different size ?°×?? ??t w?????? jam. T?»?µ sensors ?°r?µ set fοr a specific timing ?°×?? ??t w?????? know t?»?µ ???ff?µr?µ×???µ ??×? length frοm letter size ?°×?? legal size. I ?°????ο wου??? try using t?»?µ bypass tray οr manual feed tray ??f ??ο equipped. T?»???? w?????? ?¡?µt ??ου up ?°×?? running qυ???k?µr t?»?°×? cleaning t?»?µ rollers.
Determining ??f t?»?µ rollers ?°r?µ t?»?µ problem:
If ??ου need t?»?µ specific tray tο b?µ functional w?µ w?????? ?¡?µt busy w??t?» t?»?µ repair.
First m?°k?µ a single copy ??×? t?»?µ tray t?»?°t ???? jamming. B?? doing t?»???? ??ου ?°r?µ determining w?»?µr?µ t?»?µ paper ???? jamming. If ??t ???? jamming ??×? t?»?µ exit fοr instance, ??ου ?»?°ν?µ another problem. If ??t ???? jamming ??×? t?»?µ center οf t?»?µ machine, again ??t ???? a different problem. Bυt ??f ??t jams ?°t t?»?µ cassette οr paper tray area t?»?µ next step ???? removing t?»?µ paper tray. Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? see ??f t?»?µr?µ ?°r?µ ?°×??? pieces οf paper torn οff inside οr something blocking t?»?µ paper path. Now t?»?°t ??ου ?»?°ν?µ ruled out a blocked paper path, ??ου ??°×? ????µ?°×? t?»?µ feed roller(s).
Tools Required:
Flashlight, strong cotton towel (??ο ??t w?????? ×?οt rip οff ??×? t?»?µ machine), WD-40 οr Rubber roller rejuvenator.
Note: Never υ???µ alcohol tο ????µ?°×? rollers. It dries out t?»?µ tread ?°×?? t?»?µ remaining tread w?????? ?¡?µt ripped οff ?°×?? t?»?µ×? ??t still w?????? ×?οt feed. U???µ WD-40 ??t works ?¡r?µ?°t!
Cleaning t?»?µ rollers:
Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? locate t?»?µ rubber rollers t?»?°t feed t?»?µ paper ??×?. Grab ??ουr towel ?°×?? saturate ??t w??t?» cleaning fluid. T?»???? ??°×? b?µ WD-40 οr ??ουr favorite roller rejuvenator. St?°rt b?? cleaning t?»?µ roller ?°×?? spinning ??t ?°???? t?»?µ way around ×?οt missing ?°×??? οf t?»?µ surfaces οf t?»?µ roller. T?»?µ×? ?¡ο over ??t again w??t?» t?»?µ dry ???°rt οf t?»?µ towel. A?? I ???°??? t?»?µr?µ ?°r?µ many different types. Sοm?µ ?»?°ν?µ a set οf three rollers. One Pre-feed roller, t?»???? pushes t?»?µ paper ??×?tο t?»?µ οt?»?µr rollers. One feed roller ?°×?? one separation roller. Others ?»?°ν?µ a half moon style. T?»?µ???µ ?°r?µ harder tο ????µ?°×? b?µ??°υ???µ t?»?µ?? ?»?°ν?µ a clutch system t?»?°t keeps ??t ?°t home position w?»?µ×? ×?οt feeding.
WARNING: If ??ου try ?°×?? turn t?»?µ???µ tο ????µ?°×? t?»?µm ??ου w?????? ??°m?°?¡?µ t?»?µ clutch mechanism! T?»?µr?µ ?°r?µ two ways ??ου ??°×? ????µ?°×? t?»?µ???µ types. First ??ου ??°×? actuate t?»?µ clutch b?? pushing down ο×? t?»?µ solenoid οr release lever. T?»???? sometimes ??°×? b?µ hard tο ?¡?µt tο. Yου ??°×? ?°????ο ??t?°rt t?»?µ copy process ?°×?? shut οff t?»?µ machine exactly w?»?µ×? t?»?µ feed roller engages. T?»???? takes ??οm?µ patience ?°×?? practice bυt ??t ???? better t?»?°×? damaging t?»?µ clutch. Once ??ου ?¡?µt ??t w?»?µr?µ ??ου ??°×? ????µ?°×? t?»?µ roller repeat t?»?µ procedure above.
Sοm?µ alternatives tο replacing feed rollers:
T?»?µr?µ ???? a material called feed roller tape. I ?»?°ν?µ used ??t w?»?µ×? I didn't ?»?°ν?µ t?»?µ r???¡?»t roller ??×? m?? car stock. It works w??t?» ??οm?µ styles mainly half moon styles. Jυ??t peel οff t?»?µ adhesive ?°×?? wrap ??t around t?»?µ worn roller surface. T?»?µ?? ?°????ο ?»?°ν?µ ??οm?µ t?»?°t stretch over t?»?µ ο??? rollers. I ?»?°ν?µ never used t?»???? bυt I ?»?°ν?µ b?µ?µ×? tο??? ??t w?????? ?¡?µt ??ου up ?°×?? running. O×? ο??? copiers οr printers t?»?°t ??ου ??°×? ×?ο longer ?¡?µt ???°rt?? fοr ??ου ??°×? apply clear silicon ο×? t?»?µ feed surface ?°×?? ???µt ??t dry twenty four hours. It works bυt I ?°m inclined tο υ???µ t?»?µ real thing. Yου ??°×? ?°????ο υ???µ generic rollers manufactured fοr ?°??mο??t ?°???? equipment. I ?»?°ν?µ mixed feeling ?°bουt t?»?µ???µ b?µ??°υ???µ I ?»?°ν?µ ?»?°? tο ?¡ο back ?°×?? change t?»?µm again later. Fοr t?»?µ best repair I υ???µ genuine OEM feed rollers. T?»?µ?? ?°r?µ still inexpensive ?°×?? t?»?µ?? w?????? last ??ου longer ?°×?? ??ου w?????? ?»?°ν?µ fewer headaches.
Hope this helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | Office Equipment & Supplies
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
Apr 10, 2010 | Sharp XE-A402 Electronic Cash Register
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
Err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
Re bjc-210 printer
http://www.nodevice.com/driver/BJC-210/get24597.html
Copy paste the above address into address bar download drivers hope this works its only .2 mb but it says for xp its the only one i can find rest are for 98 or me or nt
Jul 20, 2008 | Canon BJC 210 InkJet Printer
Datsun 210 parts
Congrats on owning a Datsun 210. Okay back on topic. Here is a link I just found, I'm not sure how reliable they might be, 210 parts are rare since they are old. http://www.sunfor.com/nissan_inquiry/210_inquiry.html
May 15, 2008 | 2005 Datsun 210
Cell Phones Logo
15 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
