Question about Garden
Husqvarna 181 se bar oil adjustment
How to adjust a husqvarna 181 se bar oil
SOURCE: Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: can't pinpoint bar oil adjustment on 08 445
There is no externally adjustable oiler on a 445. From your manual:
"If the chain lubrication system is still not working after
carrying out the above checks and associated measures
you should contact your servicing dealer."
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Posted on Oct 15, 2009
lindsay836
  • 677 Answers
SOURCE: husqvarna 181 se chain saw
I would replace the spark plug, make SURE you have the correct gap. Make sure you are using the correct oil gas mix, I believe it is 40:1.
If that does not help you may have a bad coil.
Posted on Feb 05, 2010
  • 1514 Answers
SOURCE: i have a husqvarna 345
At the end of the bar there's a small hole. Every time you fill the oil you should also put some oil into that hole and turn the chain so it spreads into the bearing. The chain oil is not intended to be enough for that bearing. I hope that will solve your problem.
Posted on Nov 22, 2010
  • 3 Answers
SOURCE: i have a husqvarna 257 with a 20inch bar and
If you take the bar off, and then run the saw, does oil come out of the saw? If it does, then the oil pump is likely working O.K.
If the oil comes out of the saw and does not make it onto the chain, it is possible that the oil exit slot on the saw, and the hole on the bar are not lining up properly. This happened on my Husqvarna 141 saw. The oil was coming out of the saw fine, but it never made it to the bar and chain. As a consequence the chain was always dry and very, very hot.
The other saws we use, always have plenty of oil on the chain. I think Husqvarna may have made a design flaw on some of their saws, and the exit point of the saw and the entry to the bar are not properly aligned. I wonder how many saws this affects.
Posted on Sep 01, 2011
HOW AND WHERE TO ADJUST THE OILER ON THE 240 HUSQVARNA
The Husqvarna 240 does not have an adjustable oiler. Always use good quality bar and chain lube, never motor oil.
Jun 14, 2014 | Husqvarna Garden
How to adjust oil flow to bar on husqvarna 51 saw
The 51 does not have an adjustable oil pump.
Feb 16, 2014 | Husqvarna Chain Saw 20" Bar
I have a husqvarna 55 chainsaw and i'm unable to find the bar oil adjustment. does this model have adjustment screw?
The 55 does not have an adjustable oil pump, it is pre set and cannot readly be increased.
Apr 06, 2013 | Garden
I have a husqvarna 435 and its not oiling, is there an adjustment skrew anywhere? thanks
There is no oil adjustment on the 435 and these saws have bad oiling systems( leak oil badly when not is use and don't put out enough when running) , bad enough that it damages the bar and chain. The only solution is to use 30 weight engine oil ( bar oil is to thick). Crummy design.
Jan 27, 2012 | Husqvarna Garden
How to adjust bar oil flow as bar heating up too much even though chain is sharp
Not all Husqvarna models have an adjustable pump, if it is adjustable there will be a slot head screw either at the side of the sprocket, or just under neath the sprocket, there will be a small symbal of a drop of oil and a + and - sign.
Aug 22, 2011 | Husqvarna Chain Saw 20" Bar
I have a 450, and I would like to increase my bar oil output. Where is the adjustment screw? Please!
There is no adjuster for the Husqvarna 450. Husqvarna recommend that if there's not enough oil reaching the bar that you slow down the engine by adjusting the carburettor screw. I have the same saw and also wanted to adjust the oil flow. I didn't change the carburettor and it's still cutting away without doing any damage. It's meant to use less than a tank full of oil to the tank full of fuel when you're cutting near constantly. With stops in between it will use more fuel and less oil.
Nov 08, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 272 xp, setting for setting screw for oiler
To check for proper oiling, run the saw at speed with the tip of the bar near a piece of cardboard--it should throw off a thin line of oil after several moments of running. Adjust the oil adjust screw CCW for more oil. The screw is usually in the lower front or underneath the engine. Remove the bar and chain first before adjusting anything and check the oil passages located in the drive end of the bar for plugging--especially the two small passages that go from the large oil holes out to the chain groove on both sides. Start the engine without the bar and chain--look at the oil port where the bar mounts next to the engine. It should ooze out oil with the engine running fast. If nothing at all, the pump, oil lines, and oil filter in the tank should be checked. When everything seems to be working, then adjust oil flow for best operation. Hope this helps!
Apr 17, 2010 | Husqvarna Chain Saw 20" Bar
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
176 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
