Lacie Harddrive Silverscreen
May I have a driver of Lacie Silverscreen harddrive to use on Window XP ?
SOURCE: LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Posted on Jun 10, 2007
  • 33 Answers
SOURCE: LaCie silverscreen Utilities CD-ROM
The OS is hidden in memory, you can clear all files off the machine and it will still work.
The only requirements are the 4 folders:
Firmware
Movies
Music
Pictures
That's it!
New firmware can be found at www.lacie.com
Posted on Apr 10, 2008
mayur_best
  • 25 Answers
SOURCE: Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Posted on Jan 29, 2009
  • 60 Answers
SOURCE: External Harddrive Overheated
The disk in side is jammed, try throwing the harddrive like a frizbe but dont let go. That might help unsick the drive
Posted on Dec 25, 2009
not you
  • 158 Answers
SOURCE: 320gb harddrive only reconized as a 126gb
Have a look at the jumper setting,go here http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1281&p_created=&p_cats=185&p_cv=1.185&p_pv=2.194&p_prods=227%2C194#jumper This should help
Posted on May 29, 2010
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
My Lacie 500gb external hard disk has stopped working. it has a scratching like sound and no computer couldn't detect it. even it is not detected in device manager. when it is connected to computers it...
is the scratchy sound coming from inside your lacie or outside ??
it might be a power problem trying to connect to your lacie but unable to find the device or a dirty hard drive the reader arm skipping across the platters you could give your lacie a firm tap on the side to free up the reader arm
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 15, 2011 | LaCie Computers & Internet
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
My Lacie external hard drive used to turn on when the computer using XP was turned on. It has stopped doing this. Any suggestions to solve this?
if your computer came with a motherboard disc the drivers could be on it
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 12, 2011 | LaCie Computers & Internet
My computer running windows xp3 does nor discover my lacie 80gb silverscreen multimedia player. what do i do?
dry downloading its drivers thank you for using fixya and please dont forget to rate or vote me!
Jan 16, 2011 | LaCie Silverscreen 80GB USB 2.0 - Portable...
My lacie hard drive turnes on ,shows that its running,stops running and keeps showing pink light but does not show appearance on my laptop,
Right click "My Computer" and select Manage. In the window, select Disk Management on the left column. If the drive is not listed on the right column, then the BIOS has not detected the harddrive - it might have a harddrive password lock. You will need to go into the BIOS and unlock it with the password.
Nov 01, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive, http://en.wikipedia.org/wiki/File:Hard_drive-en.svg
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
http://www.lacie.com/download/datasheet/porsche_hd_en.pdf
These are examples of 3.5 inch SATA external enclosures,
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Firmware
Movies
Music
Pictures
That's it!
Dec 24, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Help me ! Lacie ED Disk Ethernet 10/100
if you are using (sata)harddrive dont install windows 98.i have a solution now before connecting your harddrive change the jumper to the slave (for single harddrive and single cd-rom or combo drive).it will work.plz install windows xp (service pack 2) or windows vista these are good versions for all!
Dec 07, 2007 | LaCie (300770) 250 GB Hard Drive
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
