Wrt 688 my tab cannot connect to cd r king router wrt622 but my notebook can.
UK Richard
  • 14 Answers
SOURCE: II have lost my wireless connection from my HP
Power off and power back on your Linksys router first. if that fails, try connecting to one of the Ethernet ports with a cable and see if the router is working in wired mode. Then download and install netstumbler software from http://www.netstumbler.com/ . This will tell you a lot of things, provided your wireless adaptors on the PC are ok.
If the router is still sending out a satisfactory wireless signal, this will show up in NetStumber, and you'll also be able to see whether there are any other (potentially conflicting) routers operating from Neighbors on the same channel as you. If you find a neighboring device on the same channel (ususally 1, 6 or 11), change the channel on your router to which ever one of these is free. Its also possible that the router config might have got itself corrupted; in which case a factory reset option could sort this out (you'd need to re-program the ISP settings, so make sure you have these first!).
Its unlikely that the MS upgrade has stopped the wireless working, but if all else fails and to eliminate all possibilities you could revert using "system restore" from the most recent recovery point.
Posted on Dec 11, 2009
govinda123
  • 2260 Answers
SOURCE: cannot connect to internet via router WRT 54GS
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 09, 2010
  • 109 Answers
SOURCE: linksys wrt 120n connected but can't browse
Check your computer's browser settings, make sure it's getting valid IP address, try pinging a website and check your IP settings under network connections.
Disable any third party firewall software you have installed.
Hope this helps!
Posted on Jul 20, 2010
Geekman
  • 32281 Answers
SOURCE: how get wifi w/router wrt
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Posted on Aug 30, 2011
RxNix
  • 26 Answers
SOURCE: why my connection speed to WRT-688 only shows 72Mbps not 150Mbps?
Ok, connection speed depends on few things:
1) Spatial streams (or pipes and antennae) you have on each side of the link (e.g. in your device's wireless card and your router)
2) Selected Channel Width ( auto, 20 or 40 Mhz).
3) Channel your router is broadcasting on and the noise and interference of neighbouring networks in the selected channel.
In order to achieve the highest wireless speed possible :
1) It is better to at least match the number of spatial streams ( or simultaneous connections in your wireless adapter,
2) Activate a channel width of auto, (which will check and switch channel width according to the good neighbour policy) or manually force it to use 40 Mhz mode (often called afterburner) both in your router and your device wifi driver. Auto mode will check if 40 Mhz mode is supported, and, if does not interfere with neighbouring networks it will switch to it automatically. 40 Mhz mode uses two channels separated by a gap of 5 channels to pass data instead of only one, so there can be signal overlapping and interference.
3) And finally, if there is congestion on any given channel you use try to set up your router so it uses a less congested one. (recommended channels are 1, 6 and 11 because with these you can have the chance to use dual channel with the least overlapping and noise).
I'm attaching the next chart because it may be useful to you when trying to understand more about wireless channels and their implications as this clearly depicts them.
Hope this helps you.
Posted on Jan 08, 2014
Why my connection speed to WRT-688 only shows 72Mbps not 150Mbps?
Jan 07, 2014 | Computers & Internet
No connection display on ethernet connections
DD-WRT firmware is very specialized. Can you ask on a site that provides support for DD-WRT ? Can you log in to the console ?
Sep 09, 2012 | Linksys E3000 Wireless Router
My wireless network connection (Realtek RTL8188CU Wireless LAN)(dd-wrt-688), the signal is not stable, how can i make it stable, since my router is working in my other computer.
Stability could be caused by other electro magnetic signals in your home or office such as cordless phones, microwaves, security systems or other wireless devices that operate within the same frequency. try turning off any of these devices and see if your wireless quality improves.
Aug 30, 2011 | Computers & Internet
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
BRIDGING MODEM AND ROUTER
Your firmware may not support bridge mode, try installing dd-wrt from http://dd-wrt.com/dd-wrtv3/index.php
Aug 19, 2009 | Linksys Wireless-G WRT54G Router
I have a WRT 150N wireless router. it is not putting out a network but i can connect to the internet with one of the lan line ports
Connect to the router via the admin screen and select the wireless tab. Check to see if wireless is set to disable or to a setting that is not compatable with your PC/laptop wireless card.
Hope that helps and thanks for using FixYa
Mar 07, 2009 | Linksys Wireless-N WRT150N Router
Wrt 100 router no showing
If the router is not broadcasting teh best way to fix this problem is to reset the router by pressing the reset button of the router for 15 seconds then afetr that run again the setup cd of the router or manually reconfigure it back....
Nov 30, 2008 | Linksys RangePlus WRT100 Wireless Router
Lynksis wrt150n .. setting
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
May 14, 2008 | Linksys Wireless-N WRT150N Router
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
