Question about Car Audio & Video
Edifier C2 amplifier repair
I have the edifier c2 ,its speakers are not working and bass is ok ,but sometimes if i use them after 2,3 days ,everything is gud ..dont know what is the problem .i have changed the leads though to check whether its wire pro or some other
My Edifier HCS2330 Amplifier stopped working and now the system is useless. Any recommendations on where to get it fixed from? Or any place i can buy the amp separately? or maybe even any other brand amp i can buy for cheap price?
Posted on Jul 20, 2014
ajdriver
  • 15 Answers
SOURCE: Vrx Bass Tube Built in amplifier
hi there mate, is the sub earthed? sometimes this might be the problem, also check that all the cables are correct in the amp, there should also be a switch on the amp to lower or increase the output, this maybe turned all the way off, the remote lead generaly is usualy the thin blue wire behind the head unit the best way to connect this to your amp remote wire is to simply go to your local halfords etc and get a little wire joining clip. then you can conect them. any other problems please ask
cheers
adam
Posted on Nov 14, 2007
perryhawk
  • 13 Answers
SOURCE: Got a used Audiobahn A1300HCX
get in touch with a pro! that lot needs to be fitted properly
good luck
Posted on Aug 05, 2008
jamesmac
  • 71 Answers
SOURCE: wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Posted on Sep 09, 2008
  • 11 Answers
SOURCE: Amplifier Powers on But Does Nothing!
Try finding a better ground some amps are more finicky about ground than others. Try running a wire from the ground on your battery to the ground on the amp if this works then you will know you need to find a better place to pick up a ground.
Posted on Jan 25, 2009
  • 17 Answers
SOURCE: how do you wire component speakers into your system
positive 2 negative bro
Posted on Jun 17, 2009
I would like to download a free Citroen C2 - 2004-1.4 Manual
Here is what you're looking for : http://www.manualslib.com/manual/641323/Citroen-C2-2004.html?page=2#manual
Jan 02, 2016 | 2006 Citroen C2 1.4
Droped phone now earphone connector in phone not working how do i fix it myself please
See local phone shop , most lightly is need sending off to be repaired
Mar 16, 2015 | Nokia C2-01.5 Black
Edifier m1350
As long as the woofer is functional, get a pair of 8 Ohm matching speakers from Radio Shack.
Jan 09, 2014 | Edifier Audio Players & Recorders
Can u tell me what amp I need to run my 2 x 400w EV sb122 bass speakers and 2 x 300w EV sx300w top speakers
The wattage listed on the speakers is the peak wattage the speakers are rated to handle. You need amplifiers that do not exceed that maximum. A 50 watt amp would drive them fairly well but you would do better with a 100 to 200 watt amplifier. Note: the speaker rating is peak power handling. Amplifiers these days are usually rated at peak output too but sometimes (old or very high quality) amplifiers are rated at sustained power (RMS). If you are working with one of these amplifiers you will need an amplifier with a lower rating. Also make sure the amplifier is designed to run the same load as the speakers. This is usually either 8 ohm or 4 ohm. Make sure the speakers and amplifier are rated the same.
Apr 17, 2013 | Audio Players & Recorders
Nokia c2-02 probulam no sim working. Shows enter code undo
Hi, I think your mobile must be network restricted. You must unlock it. The safest and easiest way to unlock a Nokia C2-02 is to unlock using unlock code. You can get the unlock code for a Nokia C2-02 from www.prounlocking.com/nokia-c2-02/rs8wp9/ at affordable cost with easy unlocking instructions.
Here are the steps for unlocking a Nokia C2-02,
1 - Switch on your Nokia C2-02 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-02.
3 - Compose #pw+CODE+1#.
4 - The Nokia C2-02 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-02 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 27, 2012 | Cell Phones
Nokia C2-01 IMEI Code?
IMEI CODE and Network unlock code are same.You can get the Nokia C2-01 IMEI unlock code at affordable cost at
Onlinegsmunlock.com/nokia-c2-01/rs7wp9/ unlock it easily..To enter the code you can follow the instructions below:
Nokia C2-01 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia C2-01 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia C2-01 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia C2-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-01.
4 - The Nokia C2-01 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-01 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
Aug 09, 2012 | Nokia C201 Cell Phone
How to connect
It is important that you an RCA connector at the end of the input to the 2.1 . You will need to connect the input to the AUDIO OUT sockets in the TV. if you are having the headphone socket please try to get a conversion jack from headphone to RCA.
Mar 31, 2010 | Bose 901 VI Main / Stereo Speaker
Need to Know the color codes of the speaker wires for a 1997 Expidition
Speaker Radio Amplifier Connector C2 Pin Radio Speaker Connector Pin Circuit LH Front 8 2 804 (O/LG) LH Rear 6 2 800 (GY/LB) RH Front 4 2 805 (W/LG) RH Rear 2 2 802 (O/R
Mar 17, 2010 | 1997 Ford Expedition
Loss of Bass
Hi there, I would think that you have blown your bass drivers in the speakers. Sometime you may have a fuse which is blown in the speaker but this is not usual. Try on another speaker if you can.
Sep 25, 2007 | NAD C370 2-Channel Amplifier
Load Clicking Noise on Deep Bass or Explosion sequences
Hi everyone having problem with B&W DM605 S2 speaker. The speakers are rated at 8ohm but during playback the impedance drops below 4ohm at low frequencies. It overloads weaker amplifiers and sometimes causes DC voltages to be injected into the speakers. Since the speakers in question are with active sub it appear that some elements on the PCB could be damaged. I would opt for LM431 (Adjustable Precision Zener Shunt Regulator) and associated elements. It could also be the rotary switch (the one used to adjust base levels - 2pole/6way) as contacts weakens over time. Possible solution: 1. switch your amp. to 4ohms 2. with the sub turned off change the position of the switch few times from max left to max right before setting it up in the desired spot.
If the problem persists: 1. replace the switch
2. replace suggested elements checking also KBL401 (Rectifier). TDA7294 (Amplifiers) are usually O.K.
Apr 18, 2007 | B&W DM605 S2 Speaker
Car Audio & Video Logo
545 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
