Question about Poulan Pro 22" Self Propelled High Wheel Mower
Shaft brigs straton
Rotor shaft pin broken and needs replacing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Do you mean Crank Keyway?
Posted on Jul 21, 2013
17hp brigs straton wont run with choke off
This is a symptom of too much air getting into the combustion chamber. Could be a broken gasket on the engine side of the carburetor. Check any areas that might allow air to be drawn in.
Oct 10, 2014 | Garden
Reach/remove pin.
Patricia, I am not sure which model you have old or new. I have the old one built in the 30's. I had to replace the shear pin and the carbon brushes for the motor. I took the bottom off which has a ball bearing resting loosely in a cavity in the bottom plate. Don't lose it. Now the brushes I found at an ace hardware. Take the old ones to compare. I think there was a bracket holding the brushes and rotor in. Once the rotor was out you could get the brushes out. Putting the brushes in required figuring out how to keep the brushes retracted. I used a piece of paper and used it hold them back while sliding in the rotor. Once in pull the paper out.
Now the shear pin needs to be in to prevent damage to the grinder in case what you are grinding has something too hard to grind like a small rock, I think if you push up on the rotor when the bottom plate is off or pulling up on the shaft it might give enough clearance to put the shear pin in. It sits very close to the bottom of the shaft so it can be fun trying to line it up. I used needle nose pliers to hold the pin just right while pulling up on the shaft. I bought the shear pin off of ebay
Mar 31, 2014 | KitchenAid A-9 Electric Burr Grinder
Need tuning instruction for 13.5 hp brigs and straton mdl 28r707
all you should have to do to a B&S 13.5hp is to change the oil, spark plug, air filter and fuel filter if it has one.
Mar 11, 2012 | Garden
Won't start
if you mean ignition rotor you need to replace the timing belt
May 05, 2009 | 1996 Volkswagen Jetta
Oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Apr 08, 2009 | Craftsman Garden
Have crafsman 5500generac generator need to seperate genhead from
Remove all wiring. Remove four stator bolts. Remove stator. remove rotor through bolt tap end of rotor us a shaft in the rotor tighten bolt in tapped hole to remove rotor.
Mar 25, 2009 | Watts Onan Portable Generator - 4000 ,...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
