Question about Refrigerators
Frigidaire refrigerator model phsc39eess5
Ef code showing after I cleaned up ice build up, unplugged for 20mins and plugged back in but EF shows up again.. Should I leave it unplugged for a longer amt of time???
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
aborcass
  • 2651 Answers
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
SOURCE: EF error code on frigidaire
My Frigidaire also got the dreaded E-F error code and stopped cooling. Technician over the phone told me to unplug it for 5 minutes and then plug it back in to see if the control board would reset itself. Did that with no luck. Unplugged the refrigerator last night while I tranferred my food to a spare fridge in the garage. Plugged the fridge back in this morning (9hrs later) and it works fine with no error codes. It looks like the control board has reset itself but how long it takes...I dont know. 10.. maybe 15 minutes? Well more than 5 at least. Guy over the phone told me that you can buy DRY ICE at a local grocery store and put it some in your freezer and a little bit in the frigdge to keep the food cold for a day. I had a spare fridge but I thought that was a good tip for anyone that needs to buy time for a tech to come repair the fridge. I had just bought $300 in groceries the night before so that tip would have come in handy if I did not have the spare fridge. I have no idea what the EF error was for but it's been 5 hours since I plugged my fridge back in and it's running fine so I'll cross my fingers. Got around to cleaning the fridge and plugging in a surge protector too. Hope this post helps someone out there.
Posted on Jan 17, 2009
SOURCE: LG EF FF Error
I found another post that suggested the following. Did it and found wires/connections frozen with a huge piece of ice.
Make sure unit is unpluged!
Removed baskets (2), unscrewed back panel of freezer. A little tricky to get out. There will be electrical connections attached to the panel but you can disconnect/reconnect these. Mine were on the top, left corner. I used a blow dryer to melt the ice chunck. Dried up all the water, replaced back, baskets.
I then took the panel off the very back of the unit as the melted ice had drained into the drip pan. I cleaned the drain pan of water, dust. They don't make this an easy task for the homeowner. Replaced the back, plugged it back in and all is working again. Don't know for how long until this happens again. But....no more LG products for this homeowner.
We remodeled the kitchen 2 years ago and went stainless steel. My 16 year old Kitchenaide is still running in the garage. Guess I'll go back to that model when the LG bits the dust.
Posted on Jul 29, 2009
SOURCE: Does anyone know what sy
http://www.retrevo.com/support/Frigidaire-FPHS2387KF-Refrigerators-manual/id/23613ag220/t/2/
Above is a link for your user manual. to download. copy past to browser.
manuals.frigidaire.com/prodinfo_pdf/Anderson/240389644.pdf
Above is the latest service sheet to do with your machine.
That SY ER is the SYtem EvapoRator Fault. This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.. you need to check.
In my professional opinion you should get a service tech to call, contact your head or local Frigidaire offic, and ask them for a referral to an authorized service agent. When there then ask for a "Quote" as to the repair, this way you can make an informed decision.
usually though a repair such as this shouldn't be too costly, however it may just be the tip of an underlying condition, which is why i suggested the professional.
Posted on Dec 17, 2010
My Frigidaire Gallery refrigerator showing HI temp.and with code5Y and EF, what does it mean?
An EF code is indicative of an Evaporator Fan Circuit Failure. Can it be stopped by ice or frost? Absolutely. Press the freezer up button and the freezer down button simultaneously for 6-8 seconds and you will enter a test mode. Every time you press the fresh food button after entering the test you will advance to the next test. They are not in numerical order. Go to test 26 (The defrost circuit test) and it will show CL for closed or OP for open. If it shows OP you have a defrost issue. If CL there is no defrost problem. Next go to test 15 - keeping in mind they ( the tests are Not in numerical order). When you get to 15 press the main power on/off button. The 1st time you press it the display will show LO and the fan should be on low speed. The next time you press the power button it will show HI, and the fan should be on high. It is a twelve vdc fan motor wire colors red, yellow, brown, and blue. They originate at the j6a and j4a connectors. If the fan does not come on in the test the check will be made at the control. There should always be 12vdc between brown and red, and there should be 9 - 12 vdc between brown and yellow in the test. The blue wire is a tach wire and feeds info back to the lower control which is located behind the kick plate underneath the unit. EX factory service 22 years currently an instructor. If you are not equipped with the proper tools and or knowledge please call a competent technician. KEEP IT SIMPLE
Feb 09, 2015 | Frigidaire Refrigerators
Why does the control panel shows 5yef
EF: Evaporator Fan issue, cannot assist on the other code. Either way, you will need a tech.
Aug 22, 2014 | Frigidaire Refrigerators
What is code 5y and ef
Hi M - I am happy to assist you! Error codes SY/EF is commonly refer to a failure with the evaporator fan circuit. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, then more than likely there is a potential wiring failure between the main control board and evaporator fan. In this regard, I would personally suggest to reaching out to a repair tech to further evaluate and repair you appliance. If you have further questions, please do not hesitate to reconnect.
Jul 18, 2013 | Frigidaire FRS26H5AS Side by Side...
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
Fungus (oil spray/mist?) on inner lens surfaces - how to disassemble and clean a Canon 75-300mm EF AF lens? A skeleton picture would also be helpful. Thanks, Tom.
Okay. I just wanted to scare you away from ruining a perfectly good (or nearly so) lens, but a learning project is a different matter. And a lens collimator is not that hard to build. One source is the book "Camera Maintenance & Repair" by Thomas Tomosy. I'm sure a quick Google search would show even more.
I did the same thing myself decades ago, taking apart a damaged zoom lens. Unfortunately, I never got it working properly again :-( But it was an educational experience, even though I didn't have a lens collimator...
Nov 13, 2010 | Canon EF 75-300mm Lens
EF code comes up.
Hi! Try this step for it usually works and has a good chance of success. Try to unplug your frigidaire from power source and leave it for a couple of hours or more. Try plugging it again and the system should reset itself. To keep your food cool inside the freezer while unplugged try to get some dry ice and put it in. Hope this helps and have a good one!
Apr 18, 2010 | Frigidaire Model: FSC23F7HSB
LG EF FF Error
Jul 28, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
