Question about MPC Computers ClientPro 565 PC Desktop
Computer will not turn on
Was working on computer it turned off, I cleaned the fan but it still will not turn on.
  • MPC Computers Master
  • 7,733 Answers
Do you had any errors on boot like a blue screen or any screen readable errors.
Posted on Jul 15, 2013
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
Computer is running hot then shuts computer down. What is this from?
Your fan that cool your computer on the inside is either so dirty it cant work properly or it doesnt work at all. They are very easy to replace just go online and look for a replacement if that is the problem. But first, open up your computer and look for the fan and see if it is dirty or not. if it is unplug your computer and clean the fan with your vacuum and or with compressed air. ( you can buy this at any computer store or Radio shack) Once you have cleaned it all up inside plug computer back in and turn on to see if this solved your problem. Remember to be extra careful anytime you are working around electronics and electricity. Hope this helps! ....... Rick
Mar 30, 2012 | Computers & Internet
My computer is making a buzzing noise the fan is working and friend told me it was probably the power supply
I would first try cleaning the computer and removing as much dust as possible from your computer. Also clean the fans, this could be the reason why your fan is working so hard. Just make sure your computer isn't turned on and not plugged in.
Nov 22, 2009 | Dell 200W ATX Power Supply K0564 Power...
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Computer isn't starting up
Recheck fan connections. I suspect the BIOS is set to protect the hardware on any fan failure. You may be able to confirm this my checking BIOS settings.
Mar 22, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
North gate computer hard to turn on
hi, how is the heatsink compound between cpu? also check the bios, make sure it is set right, bus speed, ect. you can download it if you know the brand of mainboard. and the power supply could be on its way out. contact me for more help,if this info does not help. does it just die when on for a while? or when under load? isthe cpu fan woking ok? you can download speed fan free to see. good luck hope this helps,good luck!
Mar 06, 2009 | AMD Athlon XP-2500 1.833GHz 512K 333MHz...
I have a Systemax Venture computer that is 3 years old. Just developed a problem. Turn the computer on and after 20 to 30 seconds the computer shut down. What is wrong???
Hi there.
Remove all power to the desktop, remove the side panel, power the machine up and check that CPU fan is working, if it is turn the computer back off, get a clean, dry paintbrush and gently clean the fan blades and the metal heat sync behind the fan of dust, then restart the PC to see how long it stays on for. If this time it stays on it was overheating.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Systemax Venture PC Desktop
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Robert
Jan 19, 2009 | Dell Inspiron 5150 Notebook
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
MPC Computers ClientPro 565 PC Desktop Logo
43 people viewed this question
Top MPC Computers Computers & Internet Experts
Lee Durbin
Lee Durbin
Josh Levin
Josh Levin
Laxman Bisht
Laxman Bisht
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
