Rectorseal 97637 Safe-T-Switch Ss2
The switch is overflowing
What does tcs sw off means
Toba, Transmission control switch(tcs sw) or Traction control switch. it's telling you there is a problem in transmission that needs diagnosed.
Mar 10, 2016 | 1998 Ford Windstar
I have codes C1241 and C1223 on a 2001 Toyota Sequoia. What is the possible problem?
found this on another post. Hope it helps.
c1223 absicon1.png control system abnormal
c1203 data cannot be transmited/recived to/from ECM
trouble area:
brakeicon1.png fluid
brake fluid level switch
TRC+ or TRC- CIRCUITS
SS1 or SS2 circuits
ECM
Translate ECU
Nov 01, 2013 | Toyota Sequoia Cars & Trucks
Water in the Safe-T Switch
It is a Condensate Overflow Control , your drain line may be clogged if it is clear and no water present you may have a bad sensor. If the unit is not draining properly it can cause a freeze up of the coil and compressor damage.
Jan 14, 2013 | Rectorseal Safe-T-Switch
Water will not turn off
see this causes and fix it. God bless you
Water Inlet Valve If the washer is overflowing and power is shut off to the washer, the water inlet valve has failed. Replace it.
Pressure Switch If the washer is overflowing the pressure switch might be defective. The pressure switch is attached to a small tube which is attached to the outer wash tub. As the water level rises the air pressure in the tube increases, once the set water level is reached the pressure switch turns off power to the water inlet valve. Check to be sure the air tube to the pressure switch is clear before replacing the switch.
Low Water Pressure from House Supply If the washer is overflowing the water pressure to the water inlet valve might be too low. The water inlet valve requires a minimum of 20 psi to shut off properly. If the pressure is lower, the valve may not close fully when the power is shut off. This results in the valve leaking water into the washer and causing it to overflow.
Oct 16, 2012 | Maytag Washing Machines
How to understand trouble coeds on Ford F-250 super duty truck
Trouble Code: P0743
TCC Solenoid Circuit Malfunction
Possible Causes:
TCC solenoid control circuit is open. TCC solenoid control circuit is shorted to ground. TCC solenoid wiring harness connector is damaged. TCC solenoid is damaged or it has failed. PCM has failed.Trouble Code: P0755
A/T Shift Solenoid 2/B Circuit Malfunction
Possible Causes:
SS2/B solenoid control circuit is open. SS2/B solenoid control circuit is shorted to ground. SS2/B solenoid wiring harness connector is damaged. SS2/B solenoid is damaged or has failed. PCM has failed.Trouble Code: P1747
A/T EPC Solenoid Circuit Malfunction
Possible Causes:
n/a This code doesn't have a solution.
Oct 06, 2012 | Cars & Trucks
Washer overflowed after moving Load Capacity Switch from Super to reset and then to Large load?
On this model of washer you have 4 separate components that could cause overflowing. The water valve, pressure switch, pressure switch hose & the air dome. If you have to turn the water off to prevent overflowing, I would recommend replacing the water valve. If you can turn the timer off & the water stops overflowing, I would recommend checking the pressure switch, hose & air dome.
Jan 16, 2011 | GE Washing Machines
I had a diagnostic done on my ford focus zx3 2003 and the message came back as P0755 what does this mean
P0755
PCM has failed
Feb 14, 2010 | 2003 Ford Focus
Washer tub overflowing on GE Profile WPSE4200A0WW no matter what level is set to. what test can I run to determine what component requires replacement. i have run the machine with no items in the washtub...
If you live in an area where the water is hard check the rubber hose to the barometric pressure switch. If it is loose from the tank or clogged(more likely) it will cause overflow. With the machine filling unplug the power cord, if water stops the water valve is good. The line to the baro switch connects to the back of the water level(baro)switch inside the control panel. Remove the plastic ine from the baro switch and blow down it like you are trying to fill a baloon. If you can not blow down it then it is clogged and you will have to unhook it and clean out the end where it connects to the tank. If it blows out ok then find a short pice of rubber hose connect one end to the baro switch, turn to lowest water setting and blow on it like before you should hear the baro switch click. If it dosent then it will need to be replaced.
Oct 10, 2009 | GE Profile Prodigy WPSE4200A
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
