Question about Frigidaire FRT17B3A Top Freezer Refrigerator
Freezer not Freezing and Refrigerator not cold enough
The top freezer is blowing cold air, but not freezing anything. The refrigerator is cold, but we have it set on coldest setting and it is not as cold as we would expect. This unit is in our garage. We have checked the evaporator coil and it is not frosted.
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Brian - Being that you have a top mount, the vent in the freezer is what circulates air down to the Fresh Food section, making it cool. Also keep in mind that if the garage is above 110 degrees, your refrigerator will have difficulties performing optimally due to un-circulating air. You can purchase the garage kit by going to the manufacturer website and clicking on "Filters and Accessories". Alternatively, you may be able to purchase this kit from the dealer where you purchased your appliance. Here are a few simple troubleshooting tips that may help you resolve this issue:
1. First check clearances around your refrigerator. There must be adequate space around a refrigerator with a static condenser so that air can circulate properly. Proper clearances include 1" at the back and 3" on top of the refrigerator.
2. Examine your doors. If the doors have been opened too often or for too long, this may have allowed warm air to enter the refrigerator. Make sure to shut the door completely and be sure not to keep the door open for too long. Even leaving a door slightly open can allow too much warm air intake. Make sure refrigerator is level and keep food and containers from blocking the door closing.
3. Check the door seal. You do this by placing a dollar bill between the body of the refrigerator or freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet, double check to see if the door is being blocked by anything that may be stopping it from closing. If nothing is stopping the door from closing then replace the gasket. (Most appliance owners can easily do this without any tools or sealant.)
4. Check to see if the condenser is dirty. A dirty condenser cannot release heat efficiently into the surrounding air. Cleaning the condenser may be necessary, more if you have animals in the house. If you have condenser coils, they should be wiped occasionally with a damp cloth to remove accumulated dust. The condenser coils should be wiped occasionally with a damp cloth to remove accumulated dust.
5. Check for any obstructions to the vent to ensure proper air flow. If the vent is blocked, the air in the refrigerator will not get cool.
6. Double check the freezer control. If the freezer control is set too warm, set freezer control to a colder setting and allow 24 hours for temperature to stabilize.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Posted on Jul 16, 2013
aborcass
  • 2651 Answers
SOURCE: FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Posted on Nov 30, 2008
jmgldsmth
  • 1869 Answers
SOURCE: Refrigerator does not get cold and the freezer does not freeze.
look on the back of the box for a hole marked defrost control timer turn the timer with a screwdriver if it then gets cold replace the timer
Posted on May 03, 2009
milten1
  • 1304 Answers
SOURCE: freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Posted on Oct 08, 2009
  • 1218 Answers
SOURCE: Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Posted on Jan 12, 2010
taran_2005
  • 10515 Answers
SOURCE: Hi .The freezer is cooling but refrigerator side
Read the Below Guide Written by Me:-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
I just replaced my automatic ice maker in my Samsung french door refrigerator. Now the temperature is not cold enough to freeze the water which leaves the ice bucket with water not ice. Freezer works
Repair for a Freezer That Is Running But Not Freezing ...
homeguides.sfgate.com > ... > Other Types of Mortgages
This is the heat you feel blowing near the freezer when it's in a cooling cycle. ... Also, using a freezer to cool hot items or opening the freezer frequently will ... If you noticewater pooling on the floor when the freezer is running but not freezing, ...
Why Is My Freezer Not Cold Enough? - Articles - Networx
www.networx.com > ... > Electrical > Appliance Repair > Read Article
Sep 1, 2011 - Next, make sure the freezer isn't overloaded and that the evaporator fan ... are choked with frost, restricting the airflow that makes the freezer cold. ... In verycold weather, a freezer in the garage may heat up, since there isn't enough warm ...unit (even on automatic-defrost units, in case there's a lot of water).
refrigerator - Freezer is cold but not freezing at all - Home ...
Dec 20, 2015 | Refrigerators
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
The refrigerator is not freezing
Hello Teresa, this is JK. I understand that the freezer is not cooling properly. Is the compressor running? Is there air movement through the grille at the rear of the freezer? Is there warm or cold air coming from the louvers? Can you remember any odd functions prior to this issue? If you can think of anything in particular, please feel free to reconnect and maybe it's something I can help troubleshoot. Best regards,
Mar 15, 2014 | Frigidaire Professional Top Mount...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
The freezer is not freezing its cold and the
hi thiers no problem in freezer you have 2 chect the compressor which is used 2 produces the cool gas to the freezer
Sep 14, 2009 | Amana ATB1836AR Top Freezer Refrigerator
Top of freezer not freezing, bottom of fridge is?
Could be the evaporator fan motor is not working. This is what circulates the air from the freezer to the refrigerator section.
Aug 24, 2009 | Refrigerators
Fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer not freezing and blowing luke cold air. Fan running full time.
rotate the defrost heater timer until it clicks and see if the defrost heater is working
Jun 02, 2009 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Frigidaire FRT17B3A Top Freezer Refrigerator Logo
65 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
