Question about Black & Decker Garden
110v outlet we plug our 11o to 220v what is the possible result and how to fix it?
    Top Expert:
  • Black & Decker Master
  • 42,847 Answers
The possible (likely) result is a burned out motor and the way to fix it is to replace it
Posted on Jul 15, 2013
What is required to use it as far as electrical outlet.
Dryers come in both 110V and 220V.
If you plug a 220V dryer into a 110V socket, it will run very slow.
If you plug a 110V dryer into a 220V socket, it will burn up.
If you can find a 220V extension cord, then you should be able to use it.
Mar 08, 2015 | Dryers
What will happen if inserted the 110v input d-link wireless router power supply to a 220v outlet? does my router busted or just the power supply?
Most likely you have damaged not only the power supply but also the D-Link wireless router unless the power adapter is a multi-voltage power adapter. Check the label on the power adapter and if the input voltage is a fixed 110 volt power supply you are in trouble.
You can try getting a 110v power adapter and connect it into the D-Link and if it works then you are lucky.
Dec 29, 2012 | D-Link DIR-615 Wireless Router
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
I want to put machine in my house but need 110 motor instead of 220. nothing wrong with motor or control box
I'm assuming that you brought a vacuum cleaner from a country that uses 220V to a country that uses 110V.
You either have to change the motor to a 110V motor, or find a way of plugging the cleaner into a 220V supply.
You could contact the manufacturer and ask them if they have a 110V replacement motor for your model. (Safety warning... it will take double the electrical current, which will cause four times the heating in the cable; this could be dangerous.)
A better solution would be to have an electrician fit a 220V outlet in your house. The pin arrangement will be different to prevent 110V deviced being plugged in to it. You'll have to cut the existing plug and replace it with the correct one for that voltage for your country. (I have used a British 'Dyson' in this way, plugged in to a tumble-dryer outlet; I use a GFI for extra safety.)
Jan 19, 2011 | Vacuums
Plugged my US made PC into a 220v outlet!
Hi
You need to change power supply unit. You can find a guide with screenshots here
May 03, 2009 | E-Machines eMachines Desktop PC
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Plugged 4w 120v trimmer into 220v outlet with a 50-2000w 220-110v coverter - it blew fuse and doesn't work. soldering melted off wire inside
scrap the trimmer...
probablly damaged beyond cost of new one
a step down transformer would have been a better choice than a voltage converter ( not trying to be a wise guy here)..
Nov 04, 2008 | Remington HC-600 Hair Trimmer
110v - 220v power short problem
No major worries. Only "Fuse" would have gone. You can get this replaced with some good electronic repair shops. Might charge you around Rs. 100 (else Rs. 500 since it is a "US return" item :) )
Mar 08, 2008 | Panasonic SC-HT895 System
Garden Logo
24 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
