Question about Dell SE198WFP 19 inch LCD Monitor
Plug headphone jack
What is audio jack for on se198wfp
3 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: audio jack has headphones pin broken off into it
If you have a pick set you can try prying it out of the hole with one of the picks. If you don't have one then your only option would be to replace the motherboard.
Posted on May 04, 2009
  • 6771 Answers
SOURCE: when I update my realtek audio driver my headphone/mic audio jack stops working
Do a system restore bring computer back before installation was done.
Posted on May 11, 2012
Denon 1908 no sound
Try inserting a headphone plug into the headphone jack and remove it. Sometimes these units have a problem in the headphone jack where the unit thinks there are headphones plugged in even when there isn't. This cuts all the audio output to the speaker jacks. If you never plan on using the headphone jack, you can also go inside of unit and unplug the cable that goes to the headphone jack board. Just make sure you unplug the unit before you do this, the plug is close to the main power switch.
Feb 22, 2013 | Denon AVR-1908
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
We are trying to hook our TV up to our computer to use it as a monitor. What cords do we need to do this besides the normal monitor cord?
if you want audio as well, it will depend on what kind of audio connection your tv has next to the VGA (computer monitor) connection. If it looks like the normal RCA audio, (red and white plugs) you will need to get a male headphone jack (to plug into your computer headphone or speaker out jack) to stereo RCA cable so you would have a headphone jack on one side of the cable and a red and white plug on the other side. Now if your TV just has what look like a headphone jack next to the VGA (computer monitor plug) you will need to buy a male to male stereo headphone jack cable. for both of these, just make sure the cable you get it long enough, or buy an extension.
Mar 21, 2011 | Sansui HDLCD1908 19 in. LCD TV
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
Audio only works with headphone on
may be a problem with the headphone jack & the unit thinks that a headphone is still in there. Try plugging in the headphones, putting slight tension on them plug in the jack and then pulling them out. Sometimes helps.
Feb 06, 2010 | Acer (54.AA806.001) Sound Card
Headphones
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
May 20, 2009 | HP w1907 LCD Monitor
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Adding Audio Output to TV
headphone jack is perfect. Buy ( radio shack, ebay,home depot,best buy ) the mini plug to rca breakout cable and once you plug it in it should mute speakers. Otherwise go into menu, audio, and usually there is a selection to cut off speakers
Dec 03, 2017 | Sharp 27J-S260 TV
Dell SE198WFP 19 inch LCD Monitor Logo
16 people viewed this question
Alun Cox
