Question about RCA L32HD31 32 in. LCD HDTV
Picture quality and resolution
I just bought a RCA 50" LCD TV, I plugged in HDMI cord to it and Direct TV box, and connected DVD/VCR. When I turned it on, the picture resolution: picture has green where it's dark colors and weird looking, I can't find where to change from 480i to 1080 HD picture can you please help me... My number is 9287704253
    Top Expert:
  • RCA Master
  • 75,571 Answers
Try to download its user manual by internet. It has all details.
Posted on Jul 15, 2013
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
  • 18 Answers
SOURCE: dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Posted on Jan 15, 2009
  • 4 Answers
SOURCE: green to red blinking light when plug in rca lcd
It is the capacitors on the power supply...They blew on ours...took it in a they replaced 7 for less than 100.00. Common problem with this tv because it gets hot. Hope that helps.
Posted on Nov 25, 2009
panchal643Ja
  • 243 Answers
SOURCE: Black screen on my rca lcd tv
If you can open your LCD tv than open and checked Investor Board connection or replaced
Posted on Feb 19, 2010
  • 8457 Answers
SOURCE: WON'T TURN ON
Ur controller board it dead,the one in the middle bottom of LCD screen.It a small square board.Replaced this board should have sound and picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Controller board for the replacement.
Posted on Apr 13, 2010
Trying to get the VCR/DVD recorder to record shows from direct tv using HDMI
You can not use HDMI to connect to a recorder due to blu-ray rules of no high quality recording being allowed. The only way to record off of Direct TV is to use audio and video cables (red,white and yellow.You also may need something like a videostabiizer etc. to do the job. IT IS ALL ABOUT THE MONEY!!!!!!!!
Sep 21, 2014 | Magnavox ZV427MG9 DVD Recorder VCR
How do I connect a VCR with the TV
connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
1. You can use a RF cord.
2. You can use a RCA cord.
I would suggest you use the RCA cord because the RCA connection has a better sound and display quality than the RF. So I would direct you on how to use the RCA connection method.
Here is a picture of what the RCA cord looks like for quick identification;
As you can see from the above picture that there are three cords. The Yellow cord is for display (video), while the with and red is for sound (audio Left & Right).
Turn of the VCR and the TV.
Look at the back of the VCR, connect the yellow to 'video out' and the white and red to 'audio out'. Note that the VCR might have only one audio out, that doesn't matter, just connect any of the red and white.
Now connect the other end of the cord to the back of the TV this way; Yellow will go to 'Video in' while the red & white will go to 'Audio in'.
Turn on the TV and VCR.
Select the TV to Source/AV and the display of the VCR should appear on the TV. Or better still, you can insert a cassette into the VCR, press play before selecting Source/AV on the TV.
By now the connection should be Okay.
If you any more questions or clarifications, please let me know as I would be glad to respond.....
Yours sincerely.
Elect_Comp.
May 24, 2011 | Sanyo Televison & Video
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
Just connected my 4 yr old Jwin DVD player to a new Samsung HDTV. I am using "red, white yellow" connecting cables for the "audio; video in/out" as my connection. S-Video and Coaxial...
Those RCA jacks you are using might be the problem. Lowest Quality only means your TV is ment to handle 720 to 1080 lines- the RCA cables you are using can only handle up to 500 lines. The likely culprit is the RCA cables are low quality or bent or worn. Get new RCA cables and try again. Just be sure the plugs go all the way into the connectors and the wires are not crushed or chewed on by a pet.
Jun 02, 2017 | Jwin JD-VD147 DVD Player
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I cant figure out how to plug in the direct tv cable
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Mar 07, 2009 | Akai LCT4216 42 in. LCD Television
Component Cable
Are you just using the yellow cable at this point, because the quality would in fact be awful? Using the green, red & blue cables (component cables) would not improve quality much, seeing as the yellow video cable has a resolution of 480i and component cables are set at 480p. Your TV (if it is in fact high definition) would either run at 720p or 1080p depending on what the manual says and what the native resolution is. I would say try and buy and upconvert DVD player and make sure to get an HDMI cable to go from the DVD player to the HDTV (some DVD players come with this cable, but you'll have to look around for them, otherwise look on buy.com or something for some cheap ones). HDMI connection and the upconvert DVD player will improve picture quality significantly.
Apr 23, 2008 | Televison & Video
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
RCA L32HD31 32 in. LCD HDTV Logo
65 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
