Question about Pool & Spa
What should I do if Hayward pool heater is reading error code SF??
H-Series heater. Code SF or 5F
    Problem Solver:
  • 12 Answers
The code is SF. This is a teemperature sensor failure. Check the wiring on the electroniics bord and confirm its not damaged and that it is securly plugged in. If all is good than the temperature sensor will need placing.m either a gas fitter or swimming pool reepair center will help with this is your not comfortable replacing it
Posted on Jul 18, 2013
  • 5 Answers
SOURCE: Error code LO
Is the heater installed indoors?? if so you'll need a vent pressure orifice kit.
if not check your water press. (below 18 PSI on filter) Place filter on "recir" if it fires and stays on . it's the pressure.
check to see if all connections a set tight hi-ltd switch wire harness etc.
Posted on Jun 07, 2009
SOURCE: Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Posted on Sep 16, 2009
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
Posted on Apr 23, 2010
  • 760 Answers
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Posted on Jul 05, 2010
  • 15 Answers
SOURCE: error code either 5f
Temp sensor failure. The temp sensor should be screwed into the header near the plumbing and is wired in to the control panel ( where you raise or lower pool temp) Almost positive the wire is blk/red
If you unscrew the temp sensor and its corroded ( green) try cleaning it with a wire brush, if it still doesnt work, replace the sensor. Worst case, the new sensor doesnt work, that means the old sensor was fine and its the board that its plugged into thats bad. Not likely, but always possible... sensor is much cheaper then a board so go that route first.
Posted on Aug 22, 2010
My mark 6 pool heater has power but is displaying "5f" help???
The actual reading is SF and that indicates a temperature sensor failure.
Mar 12, 2013 | Hayward 116k HeatPro Heat Pump HP3100
Where is the temp sensor on a Hayward H300 ED2 pool heater
take off top there is a copper wired unit going into header and wire to the board
Sep 18, 2012 | Hayward H-series Electronic Gas Pool...
Heater will fire up for only 5 sec. than shuts down. code read out.SF
Thank you for posting your question here on Fixya.com.
An SF error refers to the temperature sensor. Per your Hayward owner's manual:
From your manual, found here: http://www.hayward-pool.com/pdf/manuals/Manual285.pdf
The sensor screws into the inlet/outlet header and has three wires and a plug that make their way to the back of the control board. Check to see if there is damage to the wire(s) and repair if there is. Otherwise you need a new thermistor. Your part number should be IDXLTER1930.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Sep 05, 2011 | Hayward H-series Electronic Gas Pool...
HRATER WILL NOT COME ON shows a code 5F
the Code 5F is a Temperature sensor failure. The temperature sensor may be defective or the controller board may be defective. If you have an ohm meter the best way to diagnose if the sensor is faulty is to contact Hayward technical support and they can help you diagnose it. If the sensor is ok then the controller board is defective.
Aug 06, 2011 | Hayward H-series Electronic Gas Pool...
Error code either 5f or sf. any suggestions
Aug 22, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Haywood heater has code sf what does that mean
SF is a thermistor error. Once the heater cools down it should reset itself. If not, call a service tech.
Jul 03, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Mar 05, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
407 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
