Wae20261au sometimes the clothes come out of the wash after it has finished partly dry and still unwashed, dose not matter weather it's a big or small load. is the machine not filling properly at the start of the wash?
  • Washing Mach... Master
  • 16,174 Answers
Check the hoses to make sure they are ok and hot is hooked to hot and cold to cold, Make sure valves are open all the way, disconnect the hose from the washer and check to see if there are filter screens on the inlets. If this all checks out ok then you need to check the voltage at the valves during the fill cycle and if it is present, check the resistance of the valves to see if it is ok. If it is not the valves then you are looking at a control board issue. Also there is a technicians help sheet inside the unit that tells you how to use the machines diagnostics to troubleshoot the issue. To get the help sheet you need to take the panel off below the door and look for an envelope that is taped to the frame.
Posted on Jul 15, 2013
gittos73
  • 244 Answers
SOURCE: Not draining
it will be the pump they have a small fan inside them they get weak and with the pressure of the water they stop spinning which doesnt push your the water through the motor fast enough to drain properly replace and you will see the difference
Posted on Aug 22, 2007
SOURCE: why wont my machine start drying?
I called Whirlpool on 08706008989. The machine can only dry half a load of washing at a time. At the end of the washing cycle, the Programme dial should be at either the sun or half sun symbol. Remove half the washing, set the drying time via the drying time dial and press the 1/2 Load Dryer button - Voila dry clothes!
Posted on Jul 14, 2008
  • 142 Answers
SOURCE: Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Posted on Oct 19, 2008
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
woobie dog
  • 1273 Answers
SOURCE: machine fills up with water after cycle finished
You have a solenoid leaking by. Next time toy finish a load, shut of one of the water supply valves at the wall. If the water does NOT come into the machine after that, you know that you closed the right valve. Once you have determined which side (hot or cold) is leaking, follow that hose to the machine. The hose connects to the solenoid valve, which is just an electrically controlled valve that is either opened or closed. You can try to service the valve, but it is easier to remove and replace it. They don't cost much, and you can get an exact replacement at any appliance parts supply house. Total time to replace...1-1/2 hours.
Best regards, --W/D-- please feel free to rate this solution...thanx!
Posted on Aug 01, 2009
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
Not washing nor rinsing clean
see this cause:
Selector switch
test the button for open, and check if adjust properly
Clutch assembly
check the clutch and lever, see the diagram
Drive motor
the motor has failded need repair or replace see the diagram
Jun 19, 2012 | Washing Machines
My washing machine does not spin the water out of the clothes. The clothes are wet when it is finished
is the load to big for the washer? have you checked the drain tube for partial clog ? dose washer give any codes
May 06, 2011 | Whirlpool Washing Machines
There is a lot of lint especially on black clothes after wash with 6.5kg Front Load Bosch Washing Machine WAE20261AU. How to fix this issue?
Before the wash ad few cups of white vinegar to the washer half filled with water.let it run for sometime and then drain off fully.
Now for the wash add a cup of white vinegar along with the detergent. clothes be pit in inside out, cotton and polyester have different tendencies. so as towels.
So keep them for seperate washing to avoid more build up.
Sep 24, 2010 | Bosch Washing Machines
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Mildew smell on GE ESXH208
A good dose of Soda Crystals dissolved in hot water put into the machine and then ask it to do a very hot wash without any clothes in.
Place a small amount of crystals into the soap dispenser as well
You also need to try using an old fashioned soap powder such as Daz for a few weeks
Finally leave the door slightly open when you have finished washing so that the machine ahs a chance to dry out inside
Jun 27, 2009 | GE Energy Star WCVH6260F Front Load Washer
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Front load maytag duet odor
Hello. This condition is usually cause by a build up of organic matter or there is no drain trap on the waste line that the water discharge hose connects to.
First check for slime and gunk in the big rubber gasket on the front of the washer. If there is some it's an indicator that you have a build up of active bacteria. This is real common in warm damp areas. The best thing to do in prop the door open on the washer and let it dry out for a day or so. If the smell goes away then it's just bacteria. Run a full load of hot water without any clothes in it. Put the washer on the largest load with extra water, if you have that setting, and the hottest water setting, hot wash and rinse.
When it is finished open the door and let it dry overnight. You may have to do this once a month or so. also when you are finished washing leave the door to the washer open to keep it dry. Good luck.
Jan 03, 2009 | Maytag EPIC MFW9700S Front Load Washer
Neff Dishwasher
It sound like a detergent cup issue (not opened in time). The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Let me know with your results. Good luck!
Sep 05, 2007 | Neff 24 in. S5543X2 Built-in Dishwasher
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
