Question about Landice L7 LTD Executive Trainer Treadmill
Reset incline factory reset code
    Top Expert:
  • Landice Master
  • 12,223 Answers
Run the software calibration for easy diagnostic and fix it. God bless you
Posted on Jul 15, 2013
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
Factory settings for bladez t 5.9
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
go to the reset the machine for the MENU, and adjust default factory .
God bless you
Jan 14, 2013 | Bladez Exercise & Fitness
Factory reset code for nokia x3
i fogot nokia x3 securty how to reset
May 31, 2011 | Nokia X3 Cell Phone
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to manikanta.art@gmail.com
May 24, 2011 | LG Rumor Touch
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
I oppen my phone it will start to call people and then it will keep doing it even after i close the phone,and when i oppen a text my phone goes nuts
Id be inclined to reset to factory settings. You will need a security code to do this which should be in your manual.
Jun 11, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Landice L7 LTD Executive Trainer Treadmill Logo
57 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
