Question about Water Heaters
In sink erator instant hot tank leaking at the bottom of the tank
It seem the bottom of the tank is leaking. can I just patch it up with plumbing putty or replace the tank?
  • Water Heaters Master
  • 5,245 Answers
Must replace tank.
Insinkerator stainless steel tank does not have anode rod to protect against depleted tank wall.
Copy following link for tips installing under counter heater, and manuals for several different brands
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Add comment as needed and fixya will not send me email to reply with more detail
Posted on Jul 15, 2013
  • 68 Answers
SOURCE: dismantle Emerson insink erator
There is a retainer ring that holds the drain and the Insinkerator together. You loosened the drain with the 4 screws. You need to rotate the retainer ring counterclockwise when looking up from the bottom. Maybe 45 degrees and it will come loose. BE CAREFUL IT WILL WANT TO FALL!!
Phil
Posted on Dec 09, 2008
  • 4 Answers
SOURCE: Insinkerator instant hot water tank leaking
When you cut the pipe it has to be cut square or it will leak . Try recutting the end of the pipe and then reinserting it. If this doesn't work then the only thing you can do is replace the fitting.
Posted on Dec 16, 2008
jj505
  • 195 Answers
SOURCE: GE SmartWater RO Filter Tank Leaking?
I had same system under my sink for same amount of time and have since then removed entirely for health reasons related to Ro Systems. Mainly the tanks becomes contaminated [alge build up]and my faimly had constant nagging stomach aches which took a long time to resolve untill we decided to disconnected and throw out our "beloved healthy RO System" and decided to install a bi annual disposable type filter system. If you are expereanceing this I would advise the same as for the leak ,There are so many connections under there and it is usually not the tank but the fittings in lines some where and the reason it looks like the tank is because that is the lowest point the leak has traveled. So check all your fittings and if you decide on simple water filter I will advise you.
Please rate. Thanks jj505
jthomefix
gmail.com
Posted on Mar 29, 2009
pipesster
  • 20 Answers
SOURCE: size and installation for instant water heater
Ariston gl4.0 should be fine if used inline with your hot water heater. Used alone it will likely run out when dishwasher is filling and you are using sink.To use your existing hot water for backup: 1 connect existing HOT water line to cold (inlet) on ariston, 2 Then HOT (outlet) from ariston to sink and dw. If you want instant hot water at a sink 10 feet away: use 3/8 pex pipe from ariston to sink, so you only have to run off a cupful or 2 before hot water arrives at sink.
Posted on Jan 24, 2010
  • 32 Answers
SOURCE: mountain plumbing instant hot water dispenser tank is empty
most of the units have a screen on the inlet that may be plugged
Posted on Dec 10, 2010
Replace Neopreme Hose on Franke FH160?
Take the whole valve and hose out and go to hardware store etc. That undersink unit is discontinued
Jul 09, 2013 | Franke LB1100 the Little Butler Series...
Insinkerator hot tap faq
Check all the connections, take the cover off after you shut down the power. If the connectors are not leaking, replace it
May 04, 2013 | In-Sink-Erator InSinkErator HC-WAVESN-SS...
Can anyone tell me why my ISE GN1100 Hot tap is spitting when the handle is pulled back to release the water?
Usually happens when the temperature is set too high, check your instruction book and set it to the advised temp. Also the filter in the nozzle may need a clean.
Sep 15, 2012 | In-Sink-Erator InSinkErator F-GN1100SN...
For some reason, after 5 years, a small leak has developed where the hot water exits the autocirc2 tank when you turn the hot water on. I removed the fixture where the plastic tubing hooks on and the only...
It's true, nobody has 100% perfect answer for broken stuff.
Open following link for some autocirc resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
If I understand correctly, you removed supply line that connects autocirc pump to the hot water shut off valve.
Buy standard sink supply line at local box store or plumbing supply.
If memory serves, the supply line is 1/2" IP thread that connects to pump and 3/8" Compression fitting that connects to shut off.
You might try using thick-bodied white teflon joint compound to help seal the connection.
I use rectoseal on threaded connections and tubular drain connections to ensure forever seal:
http://waterheatertimer.org/images/rectoseal-006-400.jpg
If brass part of pump is cracked, then autocir may be bad.
I have no idea how to permanently fix a broken brass water fitting, and would suggest replacement at that point.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | Laing Thermotech Autocirc Undersink...
Little Gourmet Hot water tank leaks out small hole in tank bottom
this is a condensate line and suprising enough most of the plumbers I go back after never hook them up they should have a hose off of them and led to a discharge area, if this is actually on the tank you will need to drain it and remove it and reseal it,
Dec 19, 2008 | Mountain Plumbing Mountain The "Little...
InSinkErator Instant Hot Water Faucet leaking from heater unit model #GN1100
Make sure that there is no leaks traveling down the hoses or at the connections on the top. The tanks can leak, if you have the Stainless Steel tank the following information applies - Stainless Steel Tank: 3 years, with an extended service plan available when installed by an InSinkErator Pro Circle™ plumber. I you product is under warranty I believe that you can call the number that is printed on the tank and literature.
Dec 04, 2008 | Mountain Plumbing Mountain The "Little...
Dismantle Emerson insink erator
Phil
Dec 03, 2008 | Emerson InSinkErator W-152 Point-Of-Use...
Water Heaters Logo
268 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
