Question about Breville Toaster Ovens
How to remove the cover of a breville model #bov800xl toaster oven
SOURCE: Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Posted on Dec 21, 2008
protek480
  • 1723 Answers
SOURCE: how to remove grease splatter from toaster oven
Wrap the elements (gentle) in aluminum foil to keep the cleaner off the element. Then, just remove it when done!
Posted on Sep 18, 2009
kebah
  • 684 Answers
SOURCE: I need an operating manual for the Breville
Hi there.
You will be able to find Owner's Manual of Breville Convection Oven at http://www.breville.com.au
Regards.
Posted on Jul 12, 2011
rockmeister
  • 2047 Answers
SOURCE: the lcd screen on my breville toaster oven no
Hello there, the problem with your lcd screed is back-light. The back-light is the component which allows the lcd to come on. Usually replacing this is considerably simple once you have the required expertise. The LCD is usually lit up by led bulbs which are attached to the panel of the lcd on your unit. What you have to do is get replacement bulbs open up the unit un-solder the old bulbs and replace them. But if you dont have prior electrical experience please get an expert to do this as the unit does not have user servicable parts inside.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Sep 24, 2011
greenspan
  • 1734 Answers
SOURCE: need manuel and cook book for hamilton beach toaster oven/convect
I tried to locate the manual with google, but unfortunately had no success. You could ask some specialized manual search engines, like here or here. The services are not for free, but most times worthy - saved my live more than once.
Posted on Mar 15, 2013
Breville smart oven no heat or convection fan. LCD and controls working and can hear the oven clicking on.
The fan probably operated on the heat... I would tackle the THERMOSTATS, heat elements (at least 2) and/or fuse first.
My favorite supplier, appliancepartspros, struck out on Breville
(never-mind) I'll add a couple of credible ones at the bottom.
Sears parts is a good information source... but very pricey ($$$$) for the EXACT SAME PARTS you can get elsewhere...
If you can determine from your OWNERS papers which part you want to try first... get the operating parameters... and and check with a volt meter (ohms scale... power OFF)... for continuity on the FUSE, heaters & thermostat.
There is a possibility your control board (PCB) is at fault... it seems to be getting scarce... Turn it over and look for a burned/broken solder joint.
http://www.ereplacementparts.com/breville-bov800xl-smart-oven-parts-c-116052_116061_116092.html
In any case... get three prices...
In the event that PCB is the issue I do recommend LOOKING TO SEARS because of their parts support and warranty...
Good luck (finding the FUSE).
Breville BOV800XL Smart Oven Parts
Parts and Accessories
Sears Appliance Parts
Mar 04, 2016 | Breville The Smart Oven Convection Toaster...
Digital display breaking up
it happens commonly with LCD we can do nothing replace the display unit
Jun 10, 2015 | Breville The Smart Oven Convection Toaster...
The door would not close properly
www.brevilleusa.com/the-smart-oven-r.html
Website includes support. The door problem is most likely mechanical in nature and possibly could be found by simple disassemble, by anyone mechanically inclined. .
Jun 06, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
Breville bov800xl wont turn on. Reset option?.
If the screen turns on and looks like it's working but there is no heat, then the problem is the thermal fuse. It takes reassembly and a $5 replacement fuse. I replaced mine with one of the same specifications and it lasted a month. I replaced it again with one that trips at a 10 degrees higher setting and it's been good for a couple of years now.
Feb 25, 2015 | Breville BOV800XL 1800 Watts Toaster Oven...
I have a Brevelle 800 toaster oven that starts, but does not heat up. What part needs replacing?
There is a thermal fuse that breaks power to the heating elements if it gets too hot (somewhere around 173 C. I replaced mine with an identically rated fuse and it was good for a week until I tried to cook twice in succession. I then replaced the fuse with one that trips at around 190C and it's been good for 4 months now. The fuse costs about $6 on ebay (shipping included) and takes about an hour to replace.
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Breville beeping too loud
The beeping sound is annoying and mostly unnecessary. Unfortunately it can't be turned off. The only way to "fix it" would be to remove or disable the Piezo buzzer. I tried doing this, but disassembling the oven to reach the pcb control board ,where the buzzer is located, is complicated. You can take the top cover off using a Philips screw drive. But reaching the pcb board is tedious. So I gave uP and reassemble it. If someone has a better idea or method , please share. This is a great oven except for the annoying beeping. Even my dogs are afraid because it is the same sound that my invisible fence has and they think that they are being warned.
Mar 28, 2013 | Breville BOV800XL 1800 Watts Toaster Oven...
Toaster Ovens Logo
374 people viewed this question
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Raviteja
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
