Question about Radio Communications
98 freight-linerwith cummins m11 new starter smaller than orignal one was put on now I hear engine noise in the cb radio all wires are tight
  • Radio Commun... Master
  • 15,557 Answers
SOURCE: noise on cb when truck is running
im installing a in line noise filter on my power to the battery this might help too
Posted on Apr 09, 2009
  • 32 Answers
SOURCE: Tried to used CB without antena
If you were trying to transmit without the ant. then your assumption about the demise of your radio is correct.If you hooked it up using an inline fuse ,then just change the fuse. If you hooked up without a fuse, then no, you can not fix it. Please rate this answer.
  • 36 Answers
SOURCE: uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Posted on May 05, 2009
  • 39 Answers
SOURCE: wire mike to browning cb radio
1)white
2)red
shell) black and shield.
If radio keys up as soon as you plug the mic in switch the red and black wires. Good luck
Dan
Posted on Jun 27, 2009
  • 1274 Answers
SOURCE: midland cb radio 75-822, back noise and static it
sounds like your geting RF feedback...get back away from other radios and try, hope this helps ,extend the antenna......
Posted on Mar 03, 2010
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
How to remove starter dodge diesel 1998 24 valve
first turn off radio then remove negative battery cable then you have to safely raise truck support on jack stands then remove starter electrical wires.remove starter bolts then remove starter.
Jul 15, 2013 | 98 - 02 Cummins Dodge 5.9 Turbo Diesel...
I have a whine in my dash that can be heard when the engine is reved. It feeds through to my CB radio when the radio is miked up
Interference may be caused by non - resistor spark plugs. If you don't want to change your plugs for resistor plugs, you may be able to get an inline resistor for the antennae from your local electronics supply store, like radio shack. Failing that, you can buy a cb antennae with a built in resistor coil that will also do the job. If you buy the new antennae, go to a cb shop to have your antennae tuned to your cb - it will increase your range and clean up your sound too.
Hope this helps, and please rate my solution!!
Nov 17, 2010 | GMC K1500 Cars & Trucks
How to replace starter on 4cyl 1995 toyota tacom 2.4l engine
first make sure the engine is cool....disconnect the battery....locate the starter(between the engine and transmission on the bottom)...take off the starter bolt..bring the starter down and learn where the main power and signal wire at...main power it a big wire that run to the battery and the signal wire it the smaller one..so you only have two wires...take them off..than put them on the new starter and tight them down...than tight the new starter with there bolt(the ones u take off)..make sure everything is connected..hook up the battery...and fired it up...
Apr 21, 2010 | 1995 Toyota Tacoma
Excessive static equally on all chanels on cb
You should always connect the CB directly to the battery as the accessory socket is full of noise. You also should choose a better antenna as these small glass mounts cannot hear signals well and magnify local noise. AM (CBs) radios naturally pick up noise as it is the nature of AM signals. Use your squelch to lesson this but too much can knock out you reception.
Feb 14, 2010 | Cobra Radio Communications
GETTING INTERFERANCE FROM TRUCK,SQUELCH IS TURNED 3/4 ROUND TO STOP NOISE .HAVE TRIED CHANGING BOX,ARIEL,CABLE AND MOUNT,ALSO TRIED TAKING POWER STRAIGHT FROM BATTERIES, NOT SURE WHAT ELSE TO TRY?
Try this. While with the engine running and radio on, while you hear the noise, disconnect the antenna wire from the radio. (DO NOT KEY IT).
If the noise is gone, then the noise is coming in from the antenna. A new location may be needed.
If the noise is still there then its coming in from the power line. You need to get a ground loop isolator. Make sure its not one for RCA cables. You need one for the power line. It connects to your power source, and then your radio connects to it. this will take most of the noise out.
Oct 23, 2009 | Midland 1001Z 40-Channels Base CB Radio
Only makes a clicking noise and wont start
First, remove the battery terminals and clean them. Check that the ground wire on the block is tight and clean and the wire at the starter is also good. If you have 12v at the main starter cable and12v at the smaller (trigger) wire next to it with the key turned to the "start" position, it's likely the starter is bad (providing you can turn the engine by hand with key switch off) Make sure that the battery has 12v before starting diagnosis...radio etc. draw far less than the starter does. Even if relatively new, if the charging system isn't working, it will draw down the battery in less than an hour while driving..
Jun 07, 2009 | 2001 Chevrolet Tahoe
Noise on cb when truck is running
You might try running an insulated wire and ground directly from the battery.
Apr 07, 2008 | Cobra 19 DX IV CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
