Question about Aqua Vac Tiger Shark
Power supply The wires on floating cord assembly line came off of the plug that connects to the power supply. The wires and the plug are not damaged. However, where does each wire connect on the plug (One white wire and one black wire). The plug as four spots, numbered 1 through 4.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
They are wired on the top side by side
Posted on Jun 04, 2015
How to repair a torn Charger Power Cord for my Dell laptop.
It depends where the damage is, on the low voltage side or the high voltage side and how close to a plug?
When a cable is damaged to the extent it is faulty or a safety issue it is best to cut the bad part out and then join together what remains.
Now heat-shrink tubing is so widely available almost every handyman owns a selection as well as a number of soldering irons, it is possible to make good and workman-like repairs to damaged cables and with a great deal of care and patience even make them very close to the plug or the power supply and then use epoxy or a good grade of RTV silicone or polyurethane to make the joint strong again.
By using a sharp blade I have even managed to cut away moulded strain grommets to effect repairs and sometimes used a hacksaw to get inside a power supply in order to replace a cable.
The above applies mostly to the low voltage side. If the mains power cord is damaged it should be replaced if possible. If it isn't possible to replace the mains power cord a variety of small in-line joiners are available.
Dec 17, 2016 | Miscellaneous
What to do when the power is not stable
I'm not sure if you mean (1) your utility power supply is not stable or (2) your router power supply is not stable.
If (1) you can purchase an uninterruptible power supply (UPS). A line interactive unit will probably best.
If (2) the problem may be a loose or damaged power cord. Try jiggling the power cord at various points. Breaks usually occur near plugs but can occur anywhere, especially if you have biting animals around. Sometimes power plug pins can be bent slightly to improve connections. Make sure the power cord is unplugged before trying this!
Aug 13, 2016 | Computers & Internet
How to hard wire the power supply for a 2.4 ghz wireless camera model 49-2535
Warning: not only would this void the manufacturer's warranty but it could also damage or destroy the product; & you should take or use the necessary precautions to avoid electric shock or any other health risks. Since the AC power cord plugs into the back of the camera, hardwiring a power cord would require unit disassembly & replacing the manufacturer's intended power cord connection with the same power cord or one rated with the same specifications at your own risk to cut off the camera plug-in, to separate the wires, & to anchor these wires to the power jack wires of the same polarity. This could require the use of a multimeter & the use of a plastic plug anchor at the border of the hole leading into the back of the unit. The plastic anchor would serve to further secure the cord to the unit & to reduce unintended entry of moisture, dust, debris, & so forth. Take further precautions if you intend to solder the power cable to the associated wires, & secure the wires at the connections, isolating each new connection with electrical tape, Plasti-Coat, or the equivalent.
Jan 31, 2015 | Home Security
Power supply was cut
you can buy a new power cord or you can use another wire to replace the cord. just buy the same size then you will need to remove the rear cover to access the internal. and then the old cord must be removed from the ac terminal pin and the assembled wire with plug that you buy can be replaced. you can directly re soldered the end of the ac wire at the pcb for ac supply.
Aug 16, 2012 | Mitsubishi WD-57732 Projection Television
To much fuel! Boggs out! crimp fuel lin e to starve engine of gas and runs great?
Either the float level is too high or there is debris in the float needle seat. This causes the carb to overflow while running. The fix is:
- Remove the main fuel line with the fuel selector off of you have one.... or pull the line and plug it off / keep the end above the fuel tank then
- Remove the float bowl from the carb.
- Pull the float pin and remove the float and float needle (INSPECT float needle rubber tip for damage or dirt... any damage replace float needle and seat.)
- Spray carb cleaner into the main fuel supply hose / manfold fitting on the carb. Your removing any debris that night be in the float needle seat area
- Spray carb cleaner in all open fuel jet passages without dis-assembly of the carb.
- Reinstall the float needle and float (Float pin too!)
BRIEFLY reconnect the main fuel line
GENTLY lift the float to level.... (Incoming fuel flow MUST stop) Lower float.. (fuel must flow)
If the fuel flow does not stop with the float level.. you must replace the float needle snd seat. After needle and seat replacement if fuel still does not stop with the float level the tab where the float needle is will have to be bent UP no more than 0.010 at a time and then re-test flor fuel stoppage with float level. Adjust tab as necessary to get the float level correct.
- re-assemble carb
- test... running and static.
Thanks for choosing FixYa,
Kelly
Apr 26, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Dome camra wire connection with bnc
Preparation
Before installing your RCA camera scout the area and confirm that you will be able to run the cable from your surveillance digital video recorder (SDVR) to your camera. You may want to use RG59 Siamese cable, which is a single cable system with three wires: a coaxial cable for the video and a positive and negative wire to provide power to the camera. If you are installing your camera outside, place it at least 10 feet high to minimize tampering, or put your camera in a dome or other protective housing.
Coax Cable
BNC connector
BNC connectors and cable image by Albert Lozano from Fotolia.com
BNC connector
If you use Siamese cable to wire your RCA camera, you will run the cable first, and then install a BNC (bayonet Neill-Concelman--named for the inventors) connector on each end of the cable. BNC connectors vary by manufacture; install the BNC connectors according to the connector instructions. To get a general overview of the process, see the Resources section for a video on installing BNC connectors.
Power Wires
Plug with standard lamp-type cord
element electric power black image by Leonid Nyshko from Fotolia.com
Your camera came with a power supply with an integrated power wire; the power supply plugs into a standard wall outlet and the other end plugs into your camera. The cord is probably not long enough, in which case you will have to cut it and splice the Siamese in the middle to deliver power to your camera. The power supply wire is designed like a standard lamp cord and must be cut in half and split. One of the wires will be marked with a stripe, a series of dashes, a rib on the insulator or some other marking (just like a lamp cord). The marking indicates that this is the positive wire. After cutting the supply cord, connect the portion with the camera plug on it to the Siamese cable at your camera and then connect the power supply portion to the other end of the Siamese cable near your SDVR. The positive (marked) power supply wire should be connected to the red Siamese wire and the other wire connected to the black Siamese wire. While many people use wire nuts to connect the wires, connecting the wires with a wire beanie (see Resources) will provide a higher quality installation.
Plug-and-Play
Plug-and-play cables make it easier for homeowners to install their cameras. These cables incorporate all three wires into one cable system and come with connectors preinstalled so that you will not have to install connectors or cut wires. This is slightly more costly than assembling your own cable, but it will save you time and you will not have to purchase special tools to install the connectors. Run your plug-and-play cable and connect it by following the instructions which come with your cable. See the Resources section for a video on installing plug-and-play cables.
Dec 16, 2010 | Dome (8) Cctv Dome Color Ccd Night Vision...
Wiring coming from the power suply at top is burnt and i am in need of information to connect it it to plug. It is the wiring on the top of the board beside a smaller plug. Any help would be appreciated.
The power supply board is dead.That the board,where the power a/c cord plug into the board.Any connections of wires or connectors are burns.Power supply board is dead,might be effected to the other boards in the tv, that could be damaging to other boards too.But tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement first,see what happen.
Sep 22, 2010 | Dell W2600 26 in. LCD Television
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
How is float switch testing and troubleshooting ?
I use a float switch to automatically top off the water in my fishtank.  the best method I can suggest for testing the unit is to get an extension cord that you are comfortable with cutting.  Cut one of the 2 wires of the extension cord, and put the float switch in-line on this one cut wire.  Be sure to use wire nuts or something that can cover up the exposed connections where the float switch connects to the extension cord.  Once everything is buttoned up, plug the extension cord into an outlet and plug a small device which does not require much power into the other end of the extension cord, a small nightlight or something would work great.  Now move the float up and down on it's shaft to see if the connection is established to power the device.  This is essentially the same configuration that I use for my fish tank topoff and the deivce at the end of the extension cord is a pump which sits in a rubbermaid full of water.  Works great!!  Hope this helps.
Regards,
Joe
May 07, 2009 | Zoeller 10-0034 Switch-Mate Pump Float...
Replacing the electrical cord on a Roper Refrigerator
I may be able to assist...If you haven't done so already..UNPLUG The cord. Now, depending on where the wire was severed, will impact the degree of difficulty in reinstalling it.
I suggest that you position the fridge so that you can access the place where the cord actually goes into the fridge.
I assume that the cord passes thru a cable feedthru of some kind in the back so you may want to follow that into the fridge.
If the cord was severed outside the fridge you could simply join the 3 wires together as an inline connection ( making sure to keep the supply line, neutral and ground wires bonded to their corresponding ones ... meaning ground wire to ground wire, neutral to neutral and supply line to supply line... line may sometimes be referred to as the 'hot' feed.
If the cord was svered off internal to the fridge, try these steps..
You will probably need to remove an access panel on the back to see where the power cable is routed within the fridge. Once located, you will need to find where that cord was severed when it was pulled out. There should be 3 wires coming into the fridge from the power cord. I assume it came with a standard three prong plug that is compatible with a wall socket. You will have to identify which wire is which on the cord. It helps if you have a continuity meter or ohm meter for this. First, identify which of the 3 wires is bonded to the round terminal of the plug ( that would be your ground wire) That wire should be secured to the fridge frame with a bare screw of some sort. You may be able to trace the cord inside the fridge back to that point or you may be able to reattach the severed wire together using wire nuts to keep the wires joined together and electrically insulated from surrounding surfaces. Remember that it is critical to maintain the same point to point wire configuration as it came with. As a general rule of thumb, a bare copper wire or green insulated wire is typically the ground wire. Depending on the cord type, black insulated wire is normally the supply or HOT feed, and white is typically the neutral line. You may have different color insulation on your wires ( especially if it is a molded cable assembly ) so make sure you verify which wire comes from which terminal on the plug. ( round terminal on plug is ground, the longer of the two ( if it is a polarized plug would be your neutral and the shorter terminal would be the supply line. If unsure, get professional assistance. Hope this helps...
Aug 06, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Aqua Vac Tiger Shark Logo
182 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Ben Clacy
Ben Clacy
Level 1 Expert
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
