Sharp LC-70LE32U error light
Flashing error light 2 long, 5 short flashes. What does this mean. TV won't turn on.
SOURCE: the power light and OPC light flash but TV won't
try making sure tht tha scart or HDMI cable is securly fitted (depending on which one u using) and this suld solve loss of picture or sound
Posted on Jun 09, 2009
satavlad
  • 405 Answers
SOURCE: sharp lc-37sb24u. Flashing Green Light
Backlight invertor is most likely cause of the problem, in rare occasions defective CCFL lamps could cause similar symptoms. Replace defective parts, reset lamp error counter and you good to go.
Posted on Dec 02, 2009
satavlad
  • 405 Answers
SOURCE: when I turn on my
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Posted on Oct 20, 2010
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
Posted on Feb 24, 2011
budmrtn
  • 11361 Answers
SOURCE: My sharp aquos lc 37d62u will not power on; the
It is detecting shorted circuits or power supply problem, need in-depth troubleshooting. Inspect the power supply module first for any sign of bad caps with domed tops, DC output voltage readings check.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 28, 2011
Testimonial: "Very quick response and very helpful. Thank you!"
Sharp Aquos LCD TV Error Codes power flashes twice and opc flashes 5 times - What does this mean?
Sure - but you need to find out what the new error codes stand for and be guided accordingly. You might want to check on the Sharp web site.
Your t con board might also have gone south.
Jun 10, 2016 | Sharp LC-52D62U 52 in. LCD HDTV
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Sharp aquos tv, model no. lc-70c-6500u, no audio, visual at power up, standby/power light flashes 2 times long, 5 times short, nothing else happens, what is this mean?
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 28, 2015 | Sharp Televison & Video
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Sharp lc-46le830u LCD tv does not turn on white arrow flashes 2 times slow than a pause and than flashes 5 times quick .it flashes this pattern over and over.what does this code mean?
It doesn't correlate to tthe trouble code in the users manual which are written. It sounds like a motherboard error. Try a cold reboot. Unplug the TV for 2 minutes then restart the TV and anything it is attached to. Unplug all first.
Feb 17, 2013 | Sharp Aquos Televison & Video
My tv won't come on the green power light just flashes?
push and hold the power button, i did yhat to mine and it now works,also if it comes on reset the tv
Dec 12, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
