Question about Onkyo TX-SR603X Receiver
Remote control for onkyo receiver
My remote control does not communicate with my receiver. does not turn on or off or switch components.
  • 1 more comment
  • Anonymous Mar 02, 2008
    I have the same problem
  • Anonymous Feb 01, 2009
    same problem
  • gqqey Feb 03, 2009
    I have the same problem, but I believe that the problem is in the receiver, as my control can still power and control my TV and DVD player.
My situation is different. The remote control can turn on the unit and all functions are working, except that I cannot turn it off using the remote control. Anyone know why and how to fix it?
Posted on Apr 16, 2008
SOURCE:
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
I have an onkyo TX-SV515 PRO receiver and the remote speakers will not turn on. The main speakers work fine but when I depress the button to turn on the remote speakers they do not switch on.
I had the same problem. You must turn on the remote speakers via the reciever and then adjust the remote speaker volume control that is only located on the remote control. The volume buttons are on the top right of the remote. It is briefly discussed in the owners manual which can be downloaded online.<!-- from fixya rte -->
Jun 05, 2010 | Onkyo TX-SV525 Receiver
My Onkyo DR90 DVD Remote Will Not Operate Components
Your Onkyo DR90 DVD Receiver remote control does not have universal remote functions, and cannot be (easily) programmed to control a Panasonic DMR ES15. Your DR90 remote does have a limited learning function, but it is designed to learn the codes from your TV's remote to control the TV. Only the following buttons are programmable by the TV Learning function:
I hope that helps.
______________________________________________
Onkyo DR90 DVD Receiver User Manual Download.
Apr 14, 2010 | Onkyo DR90
Video Issue with Onkyo 606 when trying to watch Cable TV.
When this happens and you just see the input label try to press the power button on the front of the cable box and see if it brings the picture up. If this does produce the picture then it is a good possibility that something is interfering with the remote communicating with the cable box. I don't know if you have it contained in an entertainment center or how you have placed your equipment but if there is glass try to clean it and also wipe down the front of the cable box and make sure there is an unobstructed view of the front of the cable box.
Good Luck.
Dec 09, 2009 | Onkyo TX-SR606 Receiver
Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Sep 12, 2009 | Onkyo TX-SR606 Receiver
Dsp display on the 5.1 Onkyo receiver
Do you want to turn off the whole display?
There is a 3-way Dimmer on the front panel and the remote controller. The manual doesn't say if it will turn completely OFF.
Apr 03, 2009 | Onkyo TX-SR304 Receiver
Onkyo htr 330 universal remote codes
I have the HT-R570 Receiver and here's what I ended up doing to use the Verizon FIOS DVR remote to turn the receiver on and off with volume control. Know that Onkyo uses 2 codes 1 for on and 1 for off so use the AUX for ON with Volume control and the DVD for OFF. (I rarely use my DVD and when I do I use the DVD remote that came with the DVD)
Use the AUX and codes 1347 or 1558 to turn the receiver on with volume control. Press AUX and OK together and release. Enter the code. it should now turn the receiver ON with volume control.
To use the DVD button to turn the Receiver OFF, you have to use the search method to capture the code. Tried every code I could find on the internet and their is no universal code for OFF and ON.) With the receiver ON, push down DVD and OK together and release (should get 2 flashes of all component keys) enter 922 and with remote pointing at the receiver press the >" (forward/pause button) then press and release the >> (fast forward button) until the receiver turns off. If you go too fast and go past it, quickly turn receiver back on (within 20 seconds) and press-release the <<(backwards button) slowly until it turns off again. Then press the OK button to store the OFF code in the DVD function button. Any questions...E-Mail me at [email protected] Lots of Luck!
Nov 30, 2008 | Onkyo HTR500 Receiver
How to program onkyo tx-sr606 receiver onto remote control
I think onkyo has not come up with codes for game console yet. Codes that are available are for DVR/VCR, CD, DVD, TV. and Setup Box. I need to get the manufacturer of those components that you have for me to be able to determine which code is appropriete for your components.
Nov 23, 2008 | Onkyo TX-SR605 Receiver
TX - SR606 and Dish Network 612 HD
Hello, sorry but we do not have any additional codes. Thank you, Onkyo USA
Mar 28, 2017 | Onkyo TX-SR605 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Onkyo TX-SR603X Receiver Logo
288 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
