Question about Danby DPAC7599 Air Conditioner
Red light the red light stays on after I fill the water, what is wrong with it?
Red light stay's on after filling with water, try tuning it off and on still the sdame
Hello, hope you been using distilled water in the iron, if not you are internal problems with the iron and needs to be serviced or replace.
Dec 07, 2015 | Tefal Irons
Fix water level censor tassimo
Check to e if the magnet in the reservoir is moving up & down if not then try to place a magent on the back of the machine
Aug 26, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Descale red light, wont go off, and can i use any delcale tabs
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Mar 12, 2009 | Bosch Coffee Makers & Espresso Machines
Saeco Easy red light stays on
Make sure the magnet in the water tank flow up when you fill the water tank. Look at the dregsbox and make sure you have a little pin that goes into the machine.
Best regards
/Mirran
Oct 19, 2008 | Saeco Easy Espresso Machine
Bosch tassimo
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Indesit W123 washing machine
it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
Mar 31, 2008 | Indesit W 123 Front Load Washer
New Timer--New Problem
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Dec 12, 2006 | Admiral AW22 Top Load Washer
Danby DPAC7599 Air Conditioner Logo
18 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
