How do I turn down brightness on my hp Windows 7 computer?
I've looked everywhere and I can't find it.
  • 40 Answers
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Posted on Jul 15, 2013
  • 4 Answers
SOURCE: I have a Dell INSPIRON 5100 I can't find out how
Hold down the <Fn> Key on the bottom left side of your keyboard, then press either the <Arrow Down> or <Arrow Left>. In most cases it's the <Arrow Down> key, like on my e1505. If it doesn't work, then I would look in the control panel for Dell QuickSet. It will have options for power management, including display brightness.
If all else fails, just search in the control panel for Power management or Power Options.
Posted on Mar 01, 2009
SOURCE: My friend's touchpad does not work
Some manufacturers made a toggle that is in the upper left hand corner of the touchpad that you tap twice to toggle the touch pad on or off.
Some touchpads will have a button at the very top of the touchpad in the middle that you press to toggle the touchpad on or off.
Some manufacturers let you toggle the touchpad between on and off with keystrokes. Normally the keystrokes is to Press and Hold the ALT or FN function key then hit the correct F1 thru F12 key that toggles the keypad. Normally the correct key that toggles the keypad will have the icon of a finger pointing at a square which represents the touchpad.
You can always try to see what the manufacturer manual says about the keypad.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals.
Posted on Apr 21, 2012
SOURCE: My HP G60-630US notebook freezes during windows 7 loading up
Run the Check Disk Utility. You've got some bad or missing system or boot files.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Posted on Apr 28, 2012
bronk50
  • 27725 Answers
SOURCE: hp probook 4510s wireless isn't working
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type
each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you
have if dont need any of them you can disable or remove them
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details
or type in your default gateway adress into your internet search should read something like 10.0.0.138 to get an inertnet connection
hope it helps
Posted on Jul 17, 2012
SOURCE: How do I data fatory reset an hp compaq nx9600
Try pressing [F11] repeatedly on Start-up, to access the Factory Recovery Partition.....
However, PLEASE note that you will NOT find Windows 7 drivers for your laptop if it is that old. (confirmed, HP only supports XP on that model.)
IOW....*IF* you could manage to get win7 to install on it, it is HIGHLY likely that parts of it would not work....video, network, cardbus slot, audio.....all of these would need windows 7 drivers to work properly.
you would likely be able to see a monitor image, but not be able to change the resolution much (stuck at 800x600) and the others....would be hit and miss. and if your network adapters (LAN and WLAN) did not work, I'm not sure of what use it would be to you.....
This is one of the pit-falls in Laptop/Notebook ownership. Although some models have lasted through more than one OS, they are a tiny minority.
Posted on Sep 04, 2012
I got Error BIOHD8 on my HP Pavilion Desktop computer Please help as fast as possible.
How much RAM and how many bit operating system winows 7 32 bit requires min 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
Nov 24, 2012 | HP Computers & Internet
SYSTEM RECOVERY AFTER REPLACING HARD DRIVE
The best solution I could find was:
Boot with a Win 7 disc, and choose Repair Your Computer. Then use Startup Repair option.
bootrec /fixboot If you end up at a command prompt from the repair option.
Oct 07, 2012 | Computers & Internet
Need ethernet controller/LAN driver for HP a1620n
I have tracked down that this computer runs on Win XP 64 bit I sure hope this is correct because the processor is a 64 bit processor. And you can access the download for the drivers you need from Here. I am also going to leave you with the websites I looked at to determine what the computer is and all it's specs. which were 2 websites the first one Here and the second one Here. If you need anymore help just ask. Thanks, Cody
Sep 13, 2012 | HP Pavilion a1620n (882780664494) PC...
HP has a password want to take off password
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
May 03, 2012 | HP Computers & Internet
Apr 27, 2012 | HP G60630US Notebook
Can you install Windows 7 on another machine and use the Product Key from another machine
Unfortunately that information you've got is not correct.
You may *not* do that. 1 license, 1 installation. The rule is quite clear. It's one copy (or one license) for each computer. There's nothing new here. This is exactly the same rule that's been in effect on every version of Windows starting at least with Windows 3.1.
Apr 21, 2012 | Microsoft Windows 7 Home Premium for PC
How do i adjust brightness in hp g60
Here's how to adjust the screen brightness for a laptop in Windows 7:
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Alternatively, here is another way: From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers (f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be similiar. If you reboot the PC after using the function keys to change the LCD brightness settings, the brightness may return to the default setting on some models, which is based on the power source-battery or AC. This is not an error. The notebook is functioning as designed. If the notebook returns to the default setting after rebooting on your particular model, use the function keys to change the brightness back to the desired settings.
Aug 23, 2011 | HP G60-120US Laptop
I am on my husbands computer, however, here is my problem. I had Vista Windows on my computer. It crashed and Windows 7 was installed. Now it will not let me install my printer. I have a HP Photosmart...
Go to HP's website (hp.com), click on Support & Drivers, do a search for "Photosmart C6280", click on "Photosmart C6280", download the drivers and software for Windows 7 (you'll need to know whether you've got the 32 or 64 bit version), then follow the install instructions.
Aug 04, 2011 | HP Photosmart C6280 Printer
No audio output device is installed
LOG ONTO HP WEBSITET, TYPE MODEL ADVENT
LOOK FOR THE AUDIO DRIVER AND DOWNLOAD.
Jul 04, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
