Question about Garden
Yard pro estate series
Have an old 18hp Kohler engine lawnmower. Will run after you get it started; but dies after a few minutes. Repairman says needs an alternator - Yard Pro, Estate Series. Does this lawnmower have an alternator?
    New Friend:
  • 11 Answers
No it does not. LoL
Posted on Jul 16, 2013
2 Suggested Answers
SOURCE: I need the schematics for the yard pro estate
http://www.outdoordistributors.com/pdf/AYP/AYP-951941_%281994%29.pdf
Posted on Dec 17, 2009
Location of switch for brake pedal on 18hp Toro lawnmower that prevents cranking
most of these switches areblocated under the mower along the brake pedal shaft
Dec 04, 2017 | Toro Garden
I have a walker 18hp with kohler engine. Started it up and it ran for about a minute and cut off. turn the ignition and it won't make a sound. cleaned battery terminals and changed spark plug.
Running for about a minute sounds like fuel starvation. There could be an obstruction in the fuel tank, which allows the engine only the fuel that is in the fuel line, until it quits.
Why it won't start again is probably another matter.
Feb 09, 2017 | Kohler Engines New 18 HP Kohler Engine...
What to do? I have a craftsman GT 5000 with a 25 HP Kohler and it will run for about 10 minutes and then start cutting out and die. I have changed the fuel filter with no resolve. What should I look at...
Make sure the choke is coming off. Check the compression.Many times the head gasket may leak when the engine heats up. Also check for spark sometimes the magneto can heat up and quit after running a while. See if it will run if you prime with a little fuel, if so ,some of the Kohler engines this size have a fuel pump that could be failing. Check for vapor lock. It takes air and fuel properly mixed, spark and compression any of these missing the engine dies.
Aug 06, 2014 | Kohler Command Pro OHV Horizontal Engine...
Weedeater 300 series lawnmower
which engine does it have look where the govern spring
attaches to the throttle where it hook to the tang it is bend
able have to be careful they only should be at 3600 rpms
Oct 15, 2017 | Garden
Is it possible to replace my Kohler Command CV491S with a Kohler Command PRO CV620?
technically it is possible to do a heart trnasplant
all you need to check are the mounting flange holes or be able to drill new holes in the mower frame
and next the method of attaching the drive pulley or pto to the crank shaft has to be considered
Jul 03, 2017 | Garden
Troy Bilt Kohler 18hp riding mower won't start.
there is a main fuse . usually hidden in the wiring . contact a dealer for assistance
Oct 07, 2017 | Troy Garden
Engine dies when hot fuel not pumped round the system kohler 18hp
If the engine has a black pump on the side of the engine it may be faulty, there is a diaphram inside, but the pump is non servicable, it takes a pulse from the cylinder head or rocker box, this pulses the diaphram, which then pumps the fuel, as there is no gravity feed from the tank, it requires the pump to fill the carb.
May 19, 2012 | Garden
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Sep 19, 2009 | Garden
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
