Question about Exercise & Fitness
Pacemaster proselect error code 24
Walking is ok, even at elevations, but if you start to run, the error code 24 comes on almost instantly and shuts the whole thing down.
3 Suggested Answers
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
ercupa190
  • 12223 Answers
SOURCE: PaceMaster ProSelect Error Code 31
mean defective lower PCA or upper PCA, try to tight any plug or connector or ribbon cable, However RUN the software calibration for easy troubleshooting , and fix it.
Go under the hood motor, and follow the step how to enter in the s. calibration.,see the block diagram attached.
God bless you
Posted on Nov 13, 2012
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Pacemaster Pro Plus treadmill popping fuse
You need to replace the walking belt. Don't use the machine until you've replaced that.
May 22, 2017 | Exercise & Fitness
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Happy New Year. God bless you
Jan 01, 2013 | PaceMaster ProSelect Treadmill Incline...
Treadmill no longer asks me for my weight, and I want to reset it.
try to turn off the machine. and reset the button and try again.
Happy New year. God bless you
God bless you
Nov 12, 2012 | Exercise & Fitness
Proselect pace master treadmill incline does not work
Dear Sir:
1) You must test the Main motor board, RUN the software calibration for easy diagnose and troubleshooting.
2) The elevation motor has a Potentiomente adjust. 3) The gear from elevation motor can be LUBE. However RUN the s. calibration.
3) Another machine has relais for down and up, you must clean the relais contact, if the board has relais.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Tv shuts down and lamp error is indicated. unplugging the tv will clear the error and tv will work for hours sometimes weeks before it shuts down again
This means that the lamp, or the inverter for the lamp is just getting old and is "leaking" charge, eventually it will just turn off instantly and will no longer work.
These are not cost effective to replace, you might aswell replace the whole thing!
Sep 07, 2011 | Televison & Video
Efx 546 in diagnostics mode, flashes 255 and then real position of incline. getting error 42 when first turning machine on.
ok
elevation needs calibration or stuck
open--put elevation manually lowest and turn the unit on and bring the elevation lowest by pressing el down key
put it together clear it and start elevation will come in the starting position clear it and use it 225 is out of range of elevation
also check elevation fuse if it is good and secure
Nov 20, 2010 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
170 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
