Question about Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower ()
How to change muffler - Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower ()
    Master:
  • 969 Answers
Remove 2 bolts mounting muffler to motor.
Posted on May 28, 2014
Why is oil coming out of the exhaust pipe?
If your previous turbo had leaked oil into the exhaust system there would still be oil residue left in the system. (1) The catalytic converter/converters would need to be replaced if you have one plus any O2 sensors. (2) If your muffler/mufflers are a glass packed type, replace it with a new one. If muffler is a chamber type you can clean it with a solvent or replace your call. The muffler/mufflers are were most of the oil will be pooling. (3) Clean as much of the exhaust as you can with the solvent that you used to flush the mufflers with.
Feb 05, 2015 | Cars & Trucks
PP2075 starts with the muffler off but not with it installed. Muffler is clean - screen is clean - center facing the right way. Good fuel etc....
mufflers can be clean and still not work properly. After removing muffler and unit runs then change your muffler and clean your exhaust port while doing so
Sep 18, 2014 | Garden
Need to replace muffler on 2004 buell blast
If it is a stock muffler then buy another stock muffler and put it on - they are ALL the same. Buell never changed the exhaust on the blast at all. If it is aftermarket(vance and hines) than you need to measure the pipe and find something that fits.
Mar 03, 2013 | 2004 Buell Blast
Can i change the muffler myself
Yes it is very easy to change a muffler depending if you got the right tools take a grinder or hack saw and if the muffler is welded cut in front and in back get 2 pipe conectores if needed some u bolts or welded and good to go
Feb 28, 2011 | 1997 Pontiac Grand Am
How to install the muffler
you have not mentioned which muffler requires replacement.
The quickest and cleanest way to do a muffler job, is to take it to a muffler shop. Unless you can weld, it's an arrgavating job to complete. If you do not have a ramp to raise the vehicle, it means you will be crawling around on the ground. If you damage any pipes taking the old unit off, you will just have increased your workload. I have changed out enough mufflers and exhausts to confidently say,......let a muffler shop do it::))
Good luck.
Jan 31, 2011 | 2000 Plymouth Voyager
Can I change just the muffler on my '02 dodge neon or do I need to change the entire exhaust system?
if exhaust pipes are in good shape-no rust thru than just replace muffler
Mar 29, 2010 | 2002 Dodge Neon
I have 96 Caprice Classic...muffler has begun making quite a throaty rumble...I took to Monro Muffler...they said I need to replace from Manifold all the way to back....they want some $600. Anybody have...
I can't see your exhaust system, but I do recommend that you have them show you the "why" of it. Generally the front pipe and the cat last a long time and generally don't need to be replaced very often. If the flanges are rusted and have failed there are "wrap around" replacements that can be used without pipe replacement. Most common is to change everything from the cat back. As I said, have them actually show you what is wrong...or take it to another shop and without telling them the original findings, have them look at it!!! Since there is very little involved except a visual inspection, most shops will not charge or will charge very little for this.
Oct 21, 2009 | 1996 Chevrolet Caprice
Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower () Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
