Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Reprint batch - VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Can you print a receipt from the previous business day?
Only if it hasn't "batched" yet.
You can press the "Reprint" button (second from right purple button) to reprint the last receipt. You can also print any receipt that hasn't batched yet (normally from the current business day) by entering the receipt number. You can guess the number if you don't know it. Number 1 is the first transaction of the day, number 2 is the next one, etc.
If for some reason your transactions from the previous business day didn't get sent as a batch to the processor successfully, you would be able to print receipts for them. Otherwise, contact your processing company, and they should be able to send you a copy of the receipt.
Jun 19, 2014 | VeriFone VX510
Tip
KNOW YOUR FUNCTION CODES!
There are over 100 function codes for the terminal. Know at least the basic 1001. Batch Review03 Terminal Reset05. Batch Info/totals10. Date and Time65. Mail Order Phone Order71. enable/disable Pritner73. Reprint any Transaction82. Printer Test89. Card Reader Test95. Network Status
on Jun 18, 2014 | Hypercom Optimum T4220 Dual Terminal...
OKI ML320 Turbo - printed 100+ invoices fine in batches of 10. Got to the last 20 and it started printing the top portion of the form incorrectly and then continued to reprint the same 7 pages over and...
Unplug the network cable and restart the printer. If it sits there doing nothing then the PC's job that you sent to it is the problem. If however the printer although unplugged from network starts printing again then yes the printer memory is messed up and you will need a new main pcb as you cant clear its memory as its integral with the board.
Jul 21, 2017 | OKI MICROLINE 320 Turbo Matrix Printer
NEED TO REPRINT RECEIVED FAX HP OFFICEJET 4500
Yes, You can.
Press Settings (The Wrench Button)
Navigate to "Print Report" - Press OK
Navigate to "Reprint Faxes" - Press OK
"Reprint All Faxes" - Press OK
Or Navigate to "Reprint One" - Press OK
Navigate to Date/Time Received of fax to reprint - Press OK
May 19, 2012 | Brother IntelliFax-2820 Laser Fax
HOW DO I BATCH OUT
GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE VERIFY ONLY [F4] Press the Purple key below the More option. GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE VOID [F4] Select Batch Menu [F2]. ERASE BATCH [F1]
CLOSE BATCH [F2]
HISTORY REPORT [F3]
BATCH REPORT [F4] Select Close Batch [F2]. KEY IN MANAGER PASSWORD
AND PRESS ENTER Press [1] and [Enter]. ARE YOU SURE? CLOSE BATCH [F3]
CANCEL [F4] Select Close Batch [F3]. DIALING . . . The terminal will dial in to close the batch. Once closed, the terminal will print the batch report indicating Batch Accepted.
See example below. BATCH ACCEPTED
EXIT [F4] Select Exit [F4] to return to the menu.
Oct 19, 2011 | VeriFone VX510
How can I get the detail report print out with the settlement report when the batch closes?
Hi,after close the batch then all information flashed in your pos device so your are unable to reprint it.
psoftware109@gmail.com
Feb 28, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
WILL THIS TYPEWRITER STORE TEXT FOR LETTERING OR ENVELOPE. TO REPRINT ON DEMAND.
The only reprint is the Reprint key on the top left, but it will only reprint what you have just typed. For an addressable memory you need a WW 5, 6 or a model with save and play keys on the L. of keyboard.
DickyO
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
Printer keeps stopping halfway though run of labels. Red light comes on and when pressed goes green reprints last label then a few more then stops again.
Usually this is a sensor problem. The printer is not recognizing that the labels are moving through. Remove the labels and blow out the interior with clean air. That may resolve the problem. Dust can accumulate on the sensors and cause this.
Please update this if that does not resolve the problem.
Thanks,
Dan
Nov 04, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Can't turn off re print
If you use the SAPI (semi automatic paper insertion) feature before you type the info you want to reprint the reprint memory will only have what you typed after SAPI.
You activate SAPI by pulling the rt. upper bail arm fully forward.
DickyO
Sep 12, 2008 | Lexmark Wheelwriter 10 Series II...
Need tranz 330 detailed report for previous month
Once you "Batch Out" or do a "Settlement" on your credit card terminal you have cleared any/all transaction info from the terminal and cannot print/reprint/void any of the transactions. Detailed reports can be acquired from your processor in most cases.
Jul 08, 2008 | VeriFone 250 Matrix Printer
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
22 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
