Question about Frigidaire Washing Machines
What. is cu. ft. of Frigidaire washer GLTF1040as0 year2002
I need to replace it cause it is leaking but do not know what size to get
tzweeb
  • 318 Answers
SOURCE: trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Posted on Jan 31, 2009
SOURCE: What is the capacity (cu ft) of Kenmore washer
3.2 cubic feet
Posted on May 12, 2009
SOURCE: maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Posted on May 25, 2009
SOURCE: LG wm2101hw 4.0 cu.ft front load washer is leaking
same problem. LG stated I am using too much soap. Cant be because it still does it with no soap. Also have issues with spinning on bed comforter and also drum will not drain. I can wring out a 16oz of water from a cotton shirt sitting in the bottom of drum when completed. Floor is flooded and I am **********. Bought in April 2010 and have had 4 techs out to look at it, but there is no problem. Biggest waste of 600 I ever spent.
Posted on Sep 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
I have a broken break line that's leaking in the back on the drivers side. I need to know what size the break line is so I can bye a new one to replace it
if its leaking you should not be driving it . therefore you can take th leaking line off and take to the part store and have them give you a new one .
Feb 27, 2014 | Cars & Trucks
Only have hot water when heat is on
A stuck divert-er valve yes replace head, and know this will not cause leaks leaks,leaks are caused by o seals worn and getting old ..and olives on connections replace the above as needed some times a quick tighten with rench will do it leaks that is
Sep 28, 2013 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Air Conditioner will not charge. Think I have a leak. How much work is it to replace evaporator?
I'm a little lost here.
You normally get the high and low fittings when you buy a kit. The original system had the same size fitting for both, but the kit comes with two different sizes for R134 gauges. You may have to look for the high side fitting by itself.
How do you know the evap is leaking, or is that just a guess ?
As long as the high side fitting is closed, you should be able to charge the low side but you won't know when it is full without the high side gauge.
I would try to find the high side adapter and get the gauges hooked up before you proceed.
Jul 22, 2012 | 1986 Jaguar XJ6
My 1984 E350Econline with a 460 is leaking gas from the line and I need to know what size line it is to replace it. Thanks
If your asking about a steel tubing--measure what you need to replace
If it is rubber fuel hose--surely you can look at it,read the outside,
if it has a size or insert a drill bit to find size.
Mar 31, 2011 | Ford Econoline Cars & Trucks
Getting P1151 and P1131 codes on my 98 Ford Taurus. ''Lack of HO2S-21 and HO2S-11 Switching, Signal Low Input. Does this mean the O2 sensor(s) is defective, just durty, or some sort of vacume leak, or??
No that is it, More then likely your 02 sensor needs to be replaced.
But other possible causes would be excessive fuel pressure, leaking/contaminated fuel injectors, leaking pressure regulator, low fuel pressure or running out of fuel, vapor recovery system.
Other possible causes could be: Air leaks after the MAF, vacuum leaks.
Possible causes PVC system:
improperly seated engine oil dip-stick.
Possible causes EGR system:
Leaking gasket, stuck EGR valve, leaking diaphragm or EVR.
Possible causes Base engine:
Oil over filled, cam timing, cylinder compression, exhaust leaks before or near H02S(s).
I know its a lot of info but it could be anything. Take your time, good luck. Let me know how it is going.
Apr 26, 2010 | 1998 Ford Taurus
I have a 1999 S-10... the drivers door has a bit of a whistle while driving is there anything special i need to know to tighten up the door?? It has the third door entry and I have recently replaced a worn...
the rubber weatherstripping is dried and has shrunk in size causing this. You may not notice it for you see it everyday but it does shrink in time causing to leak air
Mar 07, 2010 | 1999 Chevrolet S-10 Pickup
How much to repair 1994 oldsmobile oil pump drive shaft o-ring
Need to know engine size. Also need to know if this "o-ring" is causing an external oil leak.
If this is a 3.1 or 3.4 engine the o-ring is a common problem. The cost should be 1-2 hours shop time. The o-ring should be minor.
Apr 26, 2009 | 1994 Oldsmobile Cutlass Supreme
Leaking
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 20, 2009 | Jenn-Air JDB4000AWS Stainless Steel...
Washing Machines Logo
232 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
