Question about Lands Phones
Telstra touchfone 300
How to turn down the ring tone
2 Suggested Answers
  • 2069 Answers
SOURCE: UNIDEN FP204 TELEPHONE DOES NOT
you should Verify that you are using the correct line cord and that it is plugged in correctly.
Posted on May 28, 2010
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
How do i store numbers in my old telstra touchfone 200
Lift up the handset and listen for dialtone.
Press [STORE] button, then dial the phone number to store, then press the [] button you want to store it to. Then simply hangup the phone and your good to go. I had to do this last night for ny parents in their nursing home. For them, you have to dial '0' to get a line out first.
So in this case you press [STORE], then '0', then the [PAUSE], then the number to store, then the button to store to. Hope this helps you.
Sep 04, 2013 | Lands Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
CALLER ID IS NOT DISPLAYING NUMBERS AND TELSTRA SAY'S IT'S NOT COMPADABLE
A Panasnic requires 3 things for CID; programming, a hardware card, and CID service from the telco.
You didn't mention it, but I'm assuming that TELSTRA delivers CID between the first and second ring via FSK modem tones, so you need an 82493 card installed in the first slot of the cabinet.
That and the proper programming mods should get you caller ID displayed on your 773x sets.
If you're getting dial tone via something other that analog(gue) POTS lines, then you're on your own :-)
Carl
Jan 13, 2011 | Panasonic KX-T7730 Corded Phone
How to change message alert on Samsung C5220
go ringtone settings and check and take ring tone for message from their you can change the tone
Oct 20, 2009 | Cell Phones
2000 Lexus RX 300 - VSC Light comes on and brake pulsation
you most likely have an "air gap" or "tone ring" problem with one of your sensors or tone rings. i would suggest letting a technician diagnos which problem it is, as it is a diagnosis that requires some experience.
Oct 20, 2009 | 2000 Lexus RX 300
Telstra 7100. we had a power cut and now the phone just flashes with base 1 ....no dialing tone ect help
Disconnect the phone line leaving the power supply still plugged in. Next page the handset from the base unit hold and press button until it bleeps (remove the handset from the base unit first). press menu and scroll down to register.... press menu .....scroll down to select base... press menu then press 1. This should reset the phone. Failing that you can ring customer services the number will be on the bottom of the base unit.
Regards Sheena.
Nov 04, 2008 | Lands Phones
Lands Phones Logo
41 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
