Question about Garden
Problem with engine continuing to run when ignition switched off
Following a new battery installed the engine ran fine,but when ignition was switched off power seemed to continue going to starter(buzzing noise). Removed battery and noise stopped. Removed battery and refitted it(when fitting cables very strong sparking noted)and engine started without switching on ignition.Removed key from ignition but engine continued to run,also disconnected cabling from ignition terminal but engine continued to run, Any solution would be gratefully accepted
3 Suggested Answers
  • 22 Answers
SOURCE: I have a Craftsman lawn tractor mower. When I turn
replace ignition switch key switch is hanging up
Posted on Sep 02, 2009
Testimonial: "Thank you. I will give that a try. It will take a few days because the part will have to be ordered from Sears."
  • 146 Answers
SOURCE: attempted to start poulan lawn
Most likely you have a short in the ignition (key) switch. Disconnect the battery first! Then look at the wires behind the ignition switch for burned or missing insulation. If all that looks OK, I would replace the ignition switch. It is also possible that your solenoid/starter assembly has failed and the solenoid has stuck in the 'on' position; but that will cost more to replace so I wouldn't start there.
Posted on Aug 16, 2010
2006 cobalt battery saver on and security light on acts Luke battery is dead but it's not, will start if you jump a wire to starter but lugs like in 2nd gear.ran fine turned it off New switch
If you installed a new ignition switch and now the security light is on than the BCM has not relearned the new ignition switch. You can google "gm security relearn" to find instructions on how to do this.
Aug 14, 2015 | Cars & Trucks
99 Navigator-Radio and heater continue to run with ignition in OFF position. Ignition switch has been changed.
Stuck ignition relay possible. With hot battery, turn key off and then feel each relay. If you find a hot one, change it.
Jan 15, 2015 | 1999 Lincoln Navigator
Cooling fan continues to run after engine shut off.
The fan runs for a short time, after ignition off, to continue to cool the hot engine.
Dec 10, 2017 | 2005 Dodge Stratus
1988 2.8 Multi Port INJ. w series Engine turns..
Crankshaft sensor is what ECU uses to fire injectors. Check it out with a voltmeter. Look for continuity, resistance and voltage. Look over connectors they are likely to be corrored or lose.
The coil is where the spark is made in this vehicle check it for leakge, resistance and voltage and corrosion .
Apr 13, 2010 | 1988 Chevrolet Celebrity
27kmiles. Runs great. Engine cuts out.
i would lean towards replacing the ignition switch.
Apr 09, 2010 | 1999 Porsche Boxster
I have a 2007 sportster it started just fine this year after about a hour ride it died after doing some checking the battery was low,so i charged it and restarted it,it ran and checked battery a week later...
Check- kill/ignition switch, spark at the plugs, voltage to starter solenoid, fuel in tank, and fuses if applicable. Last but not least the ignition module (right hand side cover).
Apr 02, 2010 | 2007 Harley Davidson XL 883 Sportster
Its not starting as good as it used to
Try running Chevron Techron concentrated fuel injector cleaner in a 1/4 tank of gas.
Also, may be the issue in this TSB.
LIGHT TRUCK: 1990-91 RANGER
1991 EXPLORER
ISSUE: A hard start or no start condition may occur when the engine is cold. The engine may not start without cycling the key to the OFF position and back to START. Ignition switch bounce (loss of electrical continuity between contacts) may cause the EDIS module to recycle several times or to lock-up and not allow a start at all.
ACTION: Install a new ignition switch containing synthetic lubricant which reduces the amount of bounce. Also, install a new wiring connector containing a new material that is compatible with the new synthetic lubricant. Refer to the following procedure for service details.
REMOVAL
  1. Disconnect the battery power.
  2. Remove the trim panel. Refer to the 1990-91 Ranger/Explorer Shop Manual, Section 11-04B, for removal procedure.
  3. Turn the lock cylinder to the RUN position.
  4. Remove the two (2) nuts on the ignition switch.
  5. Separate the connector from ignition switch by gently prying on the ears of the connector and pulling apart firmly.
  6. Disengage the terminals from the existing connector. Discard the connector.
  7. Insert terminal into proper locations in new connector (F2TZ-14489-A), Figure 1. INSTALLATION
    1. Remove the spring clip from the new switch (F2TZ-11572-A). This clip keeps the switch in the correct position during shipment.
    2. Press the new connector (F2TZ-14489-A) onto the terminals of the ignition switch. Be sure the tabs lock securely.
    3. Locate the switch on the weld studs on the steering column. NOTE: THE END OF THE ACTUATOR ROD MUST FIT IN THE HOLE ON THE SLIDER.
    4. Install the nuts on the weld stud. Tighten to 4.45-7.24N-m (39-64 lb-in).
    5. Connect the battery terminal.
    6. Check the switch operation. If necessary, adjust it. Refer to the 1990-91 Aerostar, Explorer, Ranger Truck Shop Manual, Section 11-04B, for adjustment procedure.
    7. Install the trim panel.
    PART NUMBER PART NAME F2TZ-11572-A Ignition Switch F2TZ-14489-A Wiring Connector
Nov 12, 2009 | 1991 Ford Explorer
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
