Question about Microwave Ovens
My logik N70-17 microwave is not heating. I guess the heating element is bad. How can I get a replacement?
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Is their a heating element that can go bad on a
Hi.
There is no heating element.
Here all diagrams and parts.
Regards,
Posted on Feb 05, 2010
Oven will not heat
it most likely is the thermostat which is in back it unplugs and replace. you can check with ohm meter. the other thing is the heating element which is the thick wire looking thing on the bottom it lifts up and unplugs to replace. You can check with ohm meter check resentence if nether is bad it has to be the switch on top the thing you turn to make everything go on or off easy unplug unfashion and replace. [ if no resistance on element or thermostat that is the problem then you know which one to replace ]
Sep 14, 2016 | Electrolux E30MO65GSS Convection Microwave...
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Jun 11, 2013 | Microwave Ovens
MICROWAVE WON'T HEAT
HELLO.
If you are sure that your microwave is powered on but not heating.then you are having element fault with your microwave.this is the solution below,
Things you will need
  • Oven Heating Elements
  • Screwdriver Sets
    1 Turn off the power to the microwave at the breaker box.
2 Take out the screws holding the element bracket in place. These will be on the back wall of the microwave, or sometimes on the top.
3 Pull the element toward you a little bit until you see the wires behind it.
4 Unscrew the leads and take the bad element out.
5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
7 Fasten the brackets, making sure they're tight.
8 Restore power to the appliance.
Thanks.
Sep 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works but there is no heat.
Thanks for choosing FixYa and welcome to the site. You may have a bad heating element or it may not be getting power. You need to test the wires to the element to make sure it is getting power. You could have a bad wire going to the element. If this is the case, you need to change the wire that is bad. If the wire has power, then change the heating element.
May 07, 2011 | GE JVM1440 Microwave Oven
Our American ADW1100n15BB dishwwasher does not have any hot water.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
May 05, 2011 | Microwave Ovens
10 yr old hotpoint Microwave model #RVM1325BW will not heat, vent,clock, touch pads all working.Hust no heat. If this needs to be replaced what model # should I get for the same dimensions?
I would say that your heating element has gone out. I don't know exctly what model you have, but I would guess it to be about 1.5 Cubic Ft., and a replacement would probably run somewhere around $150 to $200. There are many brands, but if I had no cost to consider, I'd probably go with a GE or Kenmore. Hope this helps.
Mar 18, 2011 | Microwave Ovens
Diswaher will not dry heating does not work
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 05, 2010 | Microwave Ovens
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Microwave arced, wont heat now
I'm assuming that it doesn't microwave either. If it does...then the heater is bad. Sears parts sells them. Second guess is a blown fuse or thermosensor. Inside the pad housing, locate the internal fuse and replace it if blown. The thermosensor is a black plastic bit about the diameter of a dime and 3/8 inch thick and clamped to the side of the unit inside the control area. Test it for continuity and replace if open. If not either of these, then you have power supply issues or control panel problems. My bet: the heater blew out. Often, this is caused when you heat greasy foods.
Dec 16, 2007 | Kenmore 69642 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
