Question about Vehicle Parts & Accessories
1990. Eagle talon car sputtering
I have a 1990 Eagle Talon TSI all-wheel-drive. This car idles fine as soon as you touch the gas pedal she starts sputtering
    Top Expert:
  • Vehicle Part... Master
  • 21,873 Answers
Is the check engine light on ?
If you have changed the air cleaner, you may have messed up the air flow for the sensors. Or it could be low fuel pressure, or a problem with the throttle position sensor. Is that hissing noise the air cleaner, or do you have a vac leak somewhere ?
Posted on Jul 15, 2013
  • jessy Jul 15, 2013
    I believe that hissing noise is the air cleaner I checked all vacuum lines all vacuum lines that's awesome same boost lines, The car has new spark plugs spark plug wires, Coil pack, Fuel filter
    It was the aftermarket air cleaner sensor, thanks you
I have a 95 eagle talon tsi ran fine then shut it off and now cranks but won't start
smack starter with hammer while someone cranks if it works its your starter. Also make sure your battery has 12 volts.
Apr 02, 2015 | 1995 Eagle Talon
When I start my 1990 Talon TSI runs fine as it warms up runs real rich has no power and boost is very high. At low RPM around 2500 its fine after that all hell brakes lose bogs down and wont go ?
check the air cleaner and replace if necessary. ( low air volume = rich mixture ). Check/clean exhaust system as back pressure may be too high at high rpm's. Check fuel quality and do not use e-mix fuels.
Sep 10, 2014 | 1990 Eagle Talon
Electrical problem - 1990 Eagle Talon TSI
the controllers in the vehicle draw a small amount of power even if the car is not running, probably enough to drain a battery over a long period of time, when you store a car it is recommended to charge the battery at least once a month
Jul 21, 2010 | 1990 Eagle Talon
What size tires come stock with the 1990 talon tsi
Look on the plate inside the door jamb of the driver's door-it has all the original info listed.
Open driver door-look at edge of door-sometimes on door jamb
Hope this helps.
Dec 14, 2009 | 1990 Eagle Talon
Boost cut
Too lean on boost. Not enough fuel.
Oct 17, 2009 | 1995 Eagle Talon
I have a 1990 talon tsi, i am having a overheating problem
WELL ON THE TALON AND ALOT OF OTHER CARS LIKE IT SOMETIMES IT WOULD BE BETTER TO RUN YOUR FAN TO A TOGGLE SWITCH ALSO WAT IT SOUNDS LIKE IS YOUR THERMOSTAT MIGHT BE GOING OUT AND IF THERE IS A CHECK ENGINE LIGHT ON YOU CAN TAKE IT TO ADVANCE AND THEY WILL DO A FREE DIAGNOSTICS FOR YOU
Jul 22, 2009 | 1990 Eagle Talon
91 talon tsi cuttin out
mine did the same thing take your turbo and ex manifold off look for cracks boost lag and replace any cracked ex parts or even turbo if cracked
Jan 10, 2009 | 1991 Eagle Talon
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
