Kenmore front loader 24 washer model 501 40002
I think the timer is broken it get stuck on 9 minute on the timer and its just keep running . i have to stop it and do the cycle again ..
  • 132 Answers
SOURCE: Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Posted on Jun 06, 2009
  • 12 Answers
SOURCE: kenmore washer won't rinse drain or spin
need new timer
Posted on Jul 31, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
VtToolMan
  • 704 Answers
SOURCE: timer gets stuck on frigidaire front load washer
It appears that your timer is failing. The process to remove and replace the faulty timer is relatively easy to do with just some simple hand tools.
You should unplug the washer from the wall outlet before taking the top backsplash (control panel) apart. There are screws on the backside of the control panel, that you need to remove the back panel. Doing this will let you get to the wiring plug connector on the timer motor.
You'll also need to remove the timer/cycle knob on the front of the panel so you can use a socket (or a adjustable wrench) to remove the mounting nut and lock washer that holds the timer to the metal panel.
Once you have everything loose and accessible, all you need to do is unplug the connectors on the old timer and out them on the new timer and reinstall the lock nut and washer and button up the panel.
That shoud be all that's needed to get things working again.
Here's link showing a drawing of your washer along wtih the parts list (and prices) for parts.
The timer is part #134378400 and costs about $89.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FTF530ES1&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROL%20PANEL&documentId=R0509003&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
Testimonial: "Thank-you for the help I'll lt you know if it works after replacing timer. scott"
blueextc3221
  • 15935 Answers
SOURCE: I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
I need to buy the timer for the kenmore 24032 \ 24036
You can buy parts for Kenmore washers from Sears Parts Direct
You need the complete model number You can find it
Front Loader
Top Load
Washer-dryer combo
Jun 22, 2011 | Kenmore 24032\24036 Top Load Washer
Gets stuck in mid cycle
you need a new timer mechanism
May 23, 2010 | Kenmore Front Load Washer
Front loader Kenmore last minute last 32 minutes
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Dec 16, 2009 | Kenmore HE2 Plus Front Load Washer
Jul 10, 2009 | LG Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Washer wont stop filling
There is probably a plastic tube running from the tub to a pressure switch which controls the water level cutoff on control panel. One can locate this by taking the backcover off and looking at the water level switch and following the tube to the connection on the tub. Tube must fit on level switch tightly for it to work properly.
Apr 27, 2009 | Kenmore 46462 Front Load Washer
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite
the time is flashing 42 on my kenmore elite front loader but when u presss the buttons noting happens
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
