Question about Comfort Zone Cz309 9 Inch Twin Window Fan With Reversible Design
Where can i get the fuse for that model fan
The fuse is not working i need to replace it where can i get it from
Hi, I have a Duracraft commercial model fan high velocity I need motor DM514
did you check already the thermal fuse and capacitor??
Oct 02, 2015 | Duracraft Dryers
Kenmore humidifier model 15420 wont turn on.
If its like mine, one or both of the fans short out causing the fuse to blow in the controller. I was running with a replaced fuse and 1 fan while waiting for a replacement fan. The remaining fan also blows the fuse now. I think maybe there is a fan issue?
Feb 23, 2014 | Kenmore 14 Gallon Humidifier Model 15420
Cigarette lighter fuse volvo
Find your fuse block, remove fuses 1 by 1 , replacing each that you find is ok with the original. (no need to replace a fuse that is still good) untill you find the blown fuse. Replace the blown fuse with a new one. A blown fuse looks like this:
ALL BLOWN FUSES WILL HAVE A BREAK IN THE MIDDLE SIMILAR TO WHAT IS SHOWN ABOVE. needle nose pliers works very well. This procedure will not take no more than a couple minutes.
Dec 05, 2013 | Cars & Trucks
HVAC Blower stopped working
The fuse you replaced powers the hvac control. The run relay is powered by a 30amp fuse in the fuse box near the battery.
Is the relay getting power from that 30amp fuse ?
Jul 10, 2013 | 2004 Saturn ION
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
The fan isnt running is it ran by a fuss
It is run by a Relay and Temperature sensor and there is a FUSE in the system, need more about the year/make/model
May 26, 2011 | Dodge Grand Caravan Cars & Trucks
My LG LMVM2055 just stopped working. i have checked the fuse box and everything is fine. i unplugged the microwave and plugged it into a working outlet and it still does not work. is there an internal...
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
Jan 09, 2011 | LG LMVM2055 Convection/Microwave Oven
I have a Chrysler town & country model 2002 where the radiator fans are no longer running. What should I believe is the problem? Fuses seems ok. Could it be the relay or some other switch? I have been...
A lot of this could have contributed to the radiator not working.. and you have already mentioned some of them. it could be the fuse or the relay or the wiring of the fan or the fan itself..
the fuse issue is easy to fix. identify the fuse box, open the lid and look on the inside for the specific fuse for the fan on the schematic there.
replace the fuse with a spare..
If the fan still does not work, approach your mechanic to check any of the other causes of the fan not working..
Need to inform you of the implications of using you car with the radiator fan not working...
Over heating has grave consequences pay attention to the gauge.....
fix problem as soon as possible.
Jan 08, 2011 | 2002 Chrysler Town & Country
Comfort Zone Cz309 9 Inch Twin Window Fan With Reversible Design Logo
19 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
