Soniq tv After moving house my soniq tv will not switch on. It didn't get damaged in the move. Any ideas?
    Champion:
  • 247 Answers
Check the kill switch at the lamp compartment it may have opened or the door doesnt press it firm enough this can cause the tv not to power up
Posted on Jul 19, 2013
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: i moved the convergence colors but didn't fix the problem
If convergence will not adjust the chips (2) need to be replaced that this set uses.
Kits are available by model number but average is around 100 and soldering and being able to get at the parts is essential.
Posted on May 01, 2012
Soniq QSP420T/2 42'' integrated Plasma TV
What is the problem you faces with this set? Try this link.
Sep 27, 2012 | Samsung TV Remote Control
Urc codes for soniq e19z10a
There is no code for Soniq with this remote control.
Aug 29, 2012 | Televison & Video
Mvx200i didn't load cassette
Are you putting the cassette in the correct way round ?
Jun 17, 2017 | Canon MVX200i Mini DV Digital Camcorder
Unlock Region Code/Instructions - Request
Just spoke with Soniq's help line in Australia. They gave me the instructions below. I have not tried them yet as I have boxed up the TV already and I am moving out of the region. Good Luck.
Unlock instructions for Soniq L37V11B
  1. Turn on TV
  2. Set to DVD Mode
  3. Press Open/Eject
  4. Leave DVD door open
  5. Press 5168 on remote
  6. This should open a Factory Menu, scroll up/down to Region Settings
  7. Change Region to 0, press Enter
  8. Press Open/Eject on remote to close the DVD door.
Soniq Help line in Australia 1300765663, option 2 then option 2
Jul 07, 2012 | Televison & Video
Recently bought a Dynex flatscreen 32 inch tv and noticed faint lines moving up the screen. Some channels it is really noticable and others not so much. Tried switching out the coax cable cord and that...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Take care in solving the problem..
Sep 12, 2011 | Dynex Televison & Video
1997 Ford Crown Victoria Ignition Cylinder locked with key in the on position and wont move forward and backwards , (Story) turned the car on and drove for a few minutes when i arrived to the house put...
you never describe what type of fuel does your car use... is it a diesel or petrol engine? if its a diesel engine then i have the correct sollution that can help you. the problem will be on the injector pump, on the main switch. change the switch and the problem will be solved. or check whether power reaches there. when it reaches then is the injector switch doesnt work to close the main valve that the car can switch off. all the best
Aug 27, 2011 | 1997 Ford Crown Victoria
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
Have a champion gun safe. Moved it to a new location. Now it won't open. Any ideas?
If your model safe has the glass relocker and you didn't re-pin the relocker when you moved it, you might have broken the glass relocker during the move. That would keep it from opening.
Jun 21, 2011 | Champion Scuba Diving & Snorkeling
When i try to move forwards after putting automatic gear on d,l,or2 car can not move but when i put it to r it can move to reverse.
There's a *very* small chance that the range switch could be shorted. Other than that, it's pretty much guaranteed that the problem is within the transmission. The fact that the car moves in reverse means that the range switch isn't out of adjustment and that one of the axles didn't come disengaged.
Jun 15, 2011 | 2004 Hyundai Elantra
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Electro Med Services...
