Question about Tools & Hardware - Others
Gate motors Centurion D10 gate motor keeps opening & closing continuously. How do I solve this problem?
4 Suggested Answers
SOURCE: gate does not open or close
What kind of gate?
Posted on Apr 19, 2009
dltatsjc
  • 54 Answers
SOURCE: Hi, My electric gate RAMSET
Look for a broken or missing shear pin that connects the drive sprocket to the motor. the pieces should still be in the sprocket and motor shaft if it is a roll pin, which I would expect, and will need to be punched out with an appropriatly sized drift pin punch, It's usually easier to drive out the pieces if the sprocket is removed from the shaft so the holes don't have to be matched up. Replace the pin with one of the same size if available, a soft steel bolt and nut may be used in a pinch but should be replaced with the proper roll pin as soon as possible.
Posted on Nov 13, 2010
  • 46580 Answers
SOURCE: Trouble shooting Centurion D10 gate motor
look for a loose wire and faulty earth check for wires shorting out to earth
Posted on Jul 15, 2013
Testimonial: "Can you advise me how to check for a wire that may be shorting to earth? I disconnected the battery terminal and switched off the mains and then re-connected and seems to be working ok now but for future reference and just general knowledge I would like to learn how to test for a shorting wire. I have a multi-meter."
Gemini gate motor
Check if it has stops anywhere in the system, usually there are micro switches that are activated by arms, etc that tell it how far to open and close. You may need to adjust them.
Aug 20, 2014 | Cars & Trucks
Centurion gate motor
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
YOU MUSt test the r.control see the photo atttached, when you hit any key the LED must be ON, and otherwise, you must open the keypads for clean from oxide, corrosion, etc. and clean the springs contacts battery, replace by new ones full charge type alkalynes. and test again.Of ocurse you can have problem too with the control motor.
God bless you
Nov 25, 2013 | Televison & Video
Jul 14, 2013 | Cars & Trucks
How to programme a nova 4 button remote on a gemini gate motor
It's important to know that the Nova remote controls are not compatible with the Gemini gate motor. In order to get these remote controls to work with your Gemini gate motor, you'll need to install a Centurion receiver first (see http://www.centsys.co.za/upload/product_link_files/CS37_Nova_Receiver_Instructions_1031.D.05.0012_4.pdf). Once the Centurion receiver has been installed on your Gemini gate motor, follow the programming instructions as per the leaflet that accompanied your brand new Nova remote control, or download the instructions from http://www.centsys.co.za/upload/product_link_files/English_Transmitter_InsertCS37_1031.D.02.0027_1_Nova.pdf
Feb 22, 2012 | Televison & Video
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
I need to program a centurion gate motor receiver
Your gate controller reciever only has one code. You must set all the remotes to that code?
Jul 15, 2009 | Home Security
Tools & Hardware - Others Logo
15 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
