Olevia 342 b11
How do I olevia 342 b11 to a coaxial cable?
5 Suggested Answers
SOURCE: Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Posted on Jan 29, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Olevia Model 342 B11. Blue
Hi Hindee11,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatal components stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Posted on Feb 14, 2011
SD Tech
  • 14553 Answers
SOURCE: My Olevia 42 inch LCD, Model 342-B11
most likely the main board but there can be problems finding parts for this brand.
Posted on Apr 30, 2012
SD Tech
  • 14553 Answers
SOURCE: Hi, My Olevia 42 inch, model342-B11, has a problem with its picture. At first I had vertical lines running down the screen, then it turned into small squares. What do you think is wrong with it?
Parts are hard or impossible to find for this brand but it sounds like the "main" board which processes all signal in and out of the display.
I need the Manual for the Olevia 537-B11 TV
Try Googling (olevia)(537-B11)(manual) without parens.
May 29, 2017 | Olevia Televison & Video
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Hi,My Olevia 342-b11 will not power on,led is lit for 10 to 15 seconds whether attempting to power on or not.
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
Nov 23, 2015 | Olevia LT42HVi 42 in. LCD Television
I have an olevia tv with an outlet for basic cable. How do I connect the cord for a cable connection? It's a 336 - B11 model
Could you tell me exactly what you want to accomplish and what you've already done please.
Aug 18, 2014 | Televison & Video
Olevia 342 b11
On the remote select menu
Go to audio input set up
Choose HDMI
Mar 25, 2014 | Televison & Video
Apr 30, 2012 | Televison & Video
Apr 30, 2012 | Olevia 742I 42 in. LCD TV
How do connect antenna lead to a olevia 332-b11 set??
Either via the cable fitting or via the av jacks from a box.
Mar 14, 2012 | Olevia 332V LCD TV
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
Nov 30, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
