Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega 29" TV screen cracked
TV screen was cracked in the shape of an arc At upper potion of the screen. There is no sign how it could have happend.Can any body tell me a reason for such a damage to occur. Can this be due to high voltage coming from a thunder storm. If sop can the TV operate for a while before it got cracked/ Please explain?
    New Friend:
  • 76 Answers
Definitely this is due to thunder. Apart from rarely following type of problem occurs through vertical section also. Before you got the screen cracked past month or past week days you observe any rainbow color screen or single horizontal line in the center of the screen means there is a chances to crack. Unless otherwise any physical damage by any other person or the above mentions symptom there is no chances to crack the tv screen. Since it is not designed like that moreover this is SONY
Posted on Sep 06, 2007
SOURCE:
Hi , I have a sony wega Trinitron 29" TV ,but my tv screen is not rectangle form and is vertical side is zoom in??
The driver transistor is gone . get another wega from a thrift store if you want for $10 or craigslist. CRT 's are getting harder to dispose with the lead shielding. you could pick up a flat screen for not much these days, Plasmas look more movie like
Mar 08, 2015 | Sony Televison & Video
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Screen goes black
Your TV have sound? If your TV have sound but no picture the problem is in the high voltage section of the crt board or try to adjust the screen adjustment.Its located in the flyback inside the TV at the back right side,the lower adjustment is the screen and upper is focus adjustment. If totaly your TV has black out check the fuse at the back if busted then replace it with same value.
Jul 11, 2011 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Realy chattering in Sony WEGA Trinitron
Hi, that is probly a capacitor in the power supply section near the relay, he failed to keep it charged
whit a good capacitor tester wizard you must be able to find and check for cracked soldering around it or directly on the relays
good luck and hope that will help you/
that is not an expensive repair;half or 1 hr time....
Mar 30, 2010 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Tv, takes 30 minutes to open after switch on
resolder all cracked solders on the jungle ic.do you have any experience in electronics?
Aug 13, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
SONY TRINITRON TV 36"
I think you had an arc in the high voltage circuit which zapped the blue drive circuit to the picture tube. This could have been caused by the high temperatures the your set was subjected to. Stargazer
Aug 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
159 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
