Question about Samsung RS263TDBP Side by Side Refrigerator
Samsung refrigerator Refrigerator fan motor not turning. Refrigerator side warm. Tested motor outside of unit by applying 12 volts. Fan works out of unit. No power to plug that supplies power to refrigerator fan (With door closed). Temperature sensor above fan reads 5 ohms. Refrigerator front panel when put in diagnostics giving fault code as R-Fan Error
SOURCE: model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Posted on Dec 30, 2008
  • 59 Answers
SOURCE: Samsung Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Posted on May 22, 2009
  • 3 Answers
SOURCE: error codes for Samsung Fridge
does anyone know what error code 3 is? Have the same problem, wont cool on fridge side freezer side is fine...
Posted on Mar 01, 2010
  • 66 Answers
SOURCE: My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
Posted on Apr 18, 2010
  • 117 Answers
SOURCE: SAMSUNG REFRIGERATOR RS21DANS 2 door side by side.
hello this may help
Posted on Sep 15, 2010
Whirlpool refrigerator model# ED25DQXDN04 - unit condenser fan motor not turning on and no power being received at condenser fan motor.
? Looking up that particular model, shows unit has regular 110v motor, if your compressor is on that fan should be as well.checking red to white wire while compressor on you should have 110 volts. if this not the case, look to a broken or disconnected wire compressor and fan should be sharing same power source.
Nov 01, 2013 | Whirlpool ED5FHEXMQ Side by Side...
Samsung model rs263osh lights on but refrigerator or freezer doesnt cool
hi bobby.both not working is not agood sign.pointing to motor falure. but try servicing the condenser unit first u might get lucky.remove rear panel and con/fan and motor should be running and cond should be warm.try this first good luck.ali
Aug 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
Inconsistent cooling, no ice, noisy fan motor.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 25, 2011 | Viking DFSB483 Side by Side Refrigerator
Evaporator fan not working!!
The fan on this model is only 12 volts. Make sure that is what your replacement is rated.
Jul 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Refrigerator and freezer both are not working. fan in back of unit running but internal fan not running. i also cannot hear the compressor kicking on.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Evap fan wont run can it be tested for bad board
Using a little 9 volt square battery , unplug the fan motor and connect the battery to the motor . ( fan runs on low voltage dc ) . If the fan runs , board is bad , if not , then motor is bad .
Jul 17, 2009 | GE GSS25SGMBS Side by Side Refrigerator
PSW26PSTASS GE S/S Food Side Warm
Take the fan out and test it sepratley,Just make sure about the volts of the fan at first, if it runs then,you got your answer...
Good luck.
Sep 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS263TDBP Side by Side Refrigerator Logo
46 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
