Question about Craftsman Garden
Engine stays running when ignition is turned off
  • Craftsman Master
  • 2,478 Answers
Bad key switch
Posted on Jul 27, 2013
Brake lights stay all time without car being on
So they stay on when the car is turned off with no engine running?
I imagine this flattens your battery?
Or do they only stay on once the ignition has been turned to "on" even without the engine running?
Could be the pedal switch sticking in which case you would simply need to look under the dash behind the pedal and try and "jiggle" the switch, though if they only stay on once the ignition is on I would lean towards a bad earth for the globe socket.
First maybe try and disconnect the pedal switch to ensure that its breaking the connection properly and turning your lights on and off.
Depending how handy you are, you could remove the tail light and run an additional earth for the globe socket.
Apr 09, 2014 | 1994 Geo Prizm
2002 f350 will not shut off with key. with key removed dash lights stay on and engine continues to run must pull injector relay to shut down. the dash lights stay on as if you turned the key to accesory...
ok well this is where you might be incorrect... either you have a 12 volt wire bleeding scross or you have a bad ignition switch. the run wire off the ignition switch is the only thing that will keep it running unless you have a remote start then of course that could keep the engine running. you might want to start by making sure the ignition switch is beaking the signal to the PCM.
Aug 27, 2011 | 2000 Ford F350 Super Duty Super Cab
I just replaced the ignition switch and lock in my 2000 alero and now it starts and runs fine but the security light is on and stays on. How do I reset this security light?
TURN THE IGNITION SWITCH TO THE ON POSITION FOR 10 MINUTES WITH ENGINE OFF.UNTIL SECURITY TURNS ITSELF OFF.THEN TURN OFF IGNITION SWITCH WAIT 5 SECONDS.THEN START THE ENGINE.IF SECURITY STILL ON DEALERSHIP HAS TO FIX.
Jan 18, 2011 | 1999 Oldsmobile Alero
When I turn my car off the air conditioner still runs-I needed a jump the other day because it ran all night and wore the battery down.
OK, if the relay for the A/C fan is bad, then the radiator's fan will keep running after turning off the ignition. Also, if the fan for ventilation of the A/C in the cabin stays on after the ignition is turned off, the relay for that is bad.
Good luck on this repair.
Sep 20, 2010 | 2001 Buick Century
Have fitted a new ignition barrel, car not running
did u try changing code reader on the barrell? it mite not be picking up the code on the key
Nov 07, 2009 | Volkswagen Golf Cars & Trucks
When it starts .. it won't stay started.
ENGINE NOT STAY RUNNING.COULD BE STOPPED UP FUEL FILTER BAD FUEL AND .FAULTY OR INCORRECT GAP PLUGS.ALSO BAD SPARK PLUG WIRES.FAULTY IGNITION SYSTEM.USE A DIAGNOSTIC SCANNER TO CHECK IDLE SPEED CODES AND MASS AIR FLOW SENSOR PROBLEMS.
Oct 16, 2009 | 2005 Chevrolet Malibu
Check light is on continuesly
there are over 200 faults that turn this ligfht on, this system is covered for 70,000 miles in most cases, have the dealer chaeck it , it will most likely be a emission warranty repair
Sep 12, 2009 | 2008 Hyundai Accent
Ignition won't stay in running position.
You are gonna need a New Ignition. Will solve this Problem.
Jan 04, 2009 | 1998 GMC Sierra
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
