Question about Philips 32PFL3403D/27 32 in. LCD TV
No power phillips lcd tv
Hello, i have a phillips lcd tv 32pfl3403d/27 there is no power to tv. No lights come on. I checked cord with meter and working fine. The fuse to power supply and caps are fine. I bought new power supply board and installed it. I have some voltage reading now on some of the wires but the number 12 on power board that connects to the inverter board has no readings. Any suggestions on what to replace. The wires do not look fried. Thank for your help
racer7x
  • 42 Answers
SOURCE: Philips 47PFL7422 Flat Screen no power
Check the main fuse
If that is ok look for puffed up capacitors on the power supply
Check the 1000ufd @ 35v change them to 1000uf @ 50volts
Good luck
Posted on Feb 08, 2009
SOURCE: attempting to connect PC to Philips 32pfl3403d TV, getting no sig
I had the same problem had to buy a s - video lead then when connected hold in function button n f4 to send the signal
Posted on May 05, 2009
  • 8457 Answers
SOURCE: Hello! I lost my power
Tries websites like Partstore.com,Ebay.com,Amazon.com to buy a replacement A/C power cord.
Posted on Feb 09, 2011
  • 8457 Answers
SOURCE: I have a phillips lcd
U have all the tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can do basic soldering and understanding of basic electronic?Yes,take out the tv power supply board,by checking it carefully ends to ends looking for dying capacitors parts,it alway bulging up on it tops or puffing up on it tops are the most common failer on the tv power supply board.By replacing all those dying capacitors,u can check the Zenith power supply board for capacitors for parts to replaced.Capacitors are very important must have the same exact micro ferit ok the voltages 5 or 10 voltages higher no problems.Take out capacitors and putting in different capacitors or new capacitors to a board must make sure polarity - + putting it in correctly to the board or will causes explosion,kill that new capacitor and more damaging to that board or the unit u tries to fix.
Posted on Feb 17, 2011
jdvillanueva
  • 2098 Answers
SOURCE: I bought this phillips plasma
Hi eltigre07,
Does it has a led light in the front panel or totally dead set?
Jdvillanueva
Posted on Mar 10, 2011
How do i channel scan on a phillips tv without remote control
Feb 18, 2015 | Philips 32PFL3403D/27 32 in. LCD TV
Phillips tv has no power
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 24, 2017 | Philips 47PFL7422D/37 Television
My tv will not come on, checked the power cord and the cord is fine. TV just does not respond whether you use the remote or the button on the side. Please advise.
Did you make sure that the cable cord was also connected to the TV? ....and also did you
check the battery in the remote -you may require a new one.....
Jun 08, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
Have a phillips 32inch lcd...turn it on and nothing happens seems like no power at all no lights no noises...tried other electronics in same outlet and it works... wondering if there is anything i can...
This is a common problem with lcd panel tv's. There is a problem with your power supply. Here are the steps you need to take.
1. Lay the tv face down on a cushioned table. Make sure the table is large enough to support the entire tv, You don't want to damage the panel.
2. Remove all the screws securing the back of the tv to the front.
3. Remove the back
4. Check the power supply pcb for puffed capacitors. If they are puffed, they need to be replaced.
5. Remove all connectors and screws from power supply pcb. This is the board where the power cord attaches.
6. Replace capacitors with equal or slightly greater valued capacitors. The values are marked on the capacitors in mfd and voltage.
7. You wil need a soldering iron to remove and replace them
8. Install the power supply pcb back into the tv and replace the connectors
9. Connect the power cord into the back of the tv and turn on.
10. Check to see if backlight comes on.
11. If it does, press menu button and lift tv up to see if you have an onscreen display. If you do the repair is complete.
If you don't you need to take a digital multimeter and check the voltage ouput from the connectors of the power supply pcb. Connect black lead of your meter to chassis ground and use the red lead and touch each individual pin to see if you have the correct voltage. The voltage levels are printed on the power supply pcb. If they are non existent, then you need to replace the power supply.
You said that you have no power light indicator led on the front panel at all. This tells me you have no standby voltage. Good luck and let me know how you make out
Apr 04, 2011 | Philips 32PFL3403D/27 32 in. LCD TV
TV wont trun on. Pull plug and wait 5min, still wont turn on. What can be done to fix this
Tv turn on?Front LCD panel LED power light indication flashing?Yes,than the power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 09, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Power light blinks red like 3-5 times and wont cut on
Pull the back out and check the SMPS. Check the main fuse to the AC line first.
May 25, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Attempting to connect PC to Philips 32pfl3403d TV, getting no sig
Mar 16, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
No audio output on Phillips 32pfl3403d
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jan 29, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Philips 32PFL3403D/27 32 in. LCD TV Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
