Question about Dell Computers & Internet
F12 function key doesn t work - Dell Computers & Internet
  • Dell Master
  • 27,725 Answers
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard.
They are located at the top of most keyboards and labeled "F1" through "F12."
Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond.
Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up.
Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key.
This key is used to toggle function-key support; when it is toggled on, the function keys will not work.
Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software.
If the key does not work, press the "F-Lock" key a second time, and test the keys again.
If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality.
Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.)
Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7
http://support.microsoft.com/kb/975741
Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard
http://support.microsoft.com/kb/894513
Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database.
Agree to the terms and conditions, then download the hotfix.
When the download is finished, run the downloaded file and follow the on-screen instructions.
You may need to restart your computer after the installation is complete.
Your function keys should now work properly.
Posted on Jul 15, 2013
What do I do when my acer r-1600 will not respond to the " F12 " button instructions?
what function does the F12 button do? maybe the program you are using doesnt make use of this function key, in which case nothing will happen. do other function keys work OK? maybe you need to push a Fn button as well to activate the F12 key. have you tried a different keyboard?
Oct 19, 2014 | Acer Revo Ar1600 Desktop Atom 230 1.6 Ghz...
My function keys doesn't work in my laptop toshiba satellite c660-a047
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
Jan 09, 2013 | Toshiba satellite c660
Only F12 doesn't work, all other function keys work
If your running on OS Lion than all it does is take you to your dashboard. So if you don't use it that much than its nothing to really worry about. An alternate way to get there is by using the multi-gesture trackpad and swipe with 4 fingers to the left.
May 28, 2012 | Apple Computers & Internet
Im trying to restore my dell pc back to factory settings its running vista f8 is not working i can only use f2 and f12
I would recommend using the Dell factory restore DVD. It probably didn't come with your computer (companies save money by not shipping a DVD with the computer). You can order it from Dell and it will probably cost less than $20.
Many times the restore function by hitting a special function key at startup becomes corrupt and doesn't work.
I'd opt for a new DVD to use.
Apr 18, 2012 | Dell Computers & Internet
Which switch will turn on the wireles net connection
The keys along the top ranging from F1 to F12 will have icons on them. you will need to locate the icon that resembles a WiFi tower or radio signal.
By default the F1-F12 keys are inverted performing their functions such as turning WiFi on and off so the Fn key will not need to be pressed unless you have changed this setting (typically in the BIOS). If pushing the button with or without the Fn doesn't turn your WiFi on and off then you may be missing the software needed for this to function correctly and you will need to visit Dell to download applications related to your wireless.
Nov 28, 2011 | Dell Inspiron Mini 1012 Netbook...
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
Hi I have just bought an Acer Aspire Z5710 all-in-one PC. I find the screen too bright when working for long, and want to adjust the brightness. But i am not able to figure out how to do so. And there...
http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z5700_Z5710_20100907.pdf
If the keyboard doesn't have a Fn key often the Scroll Lock key is used, try Scr Lk + Down arrow to dim the display.
The manual indicates and Fn Key to the right of the Left Alt Key but that doesn't mean you have that keyboard eitther
Jun 30, 2011 | Computers & Internet
F keys suddenly not working
The "F mode" button toggles on and off the F keys. If you press it (accidentally) as I did, the keys will no longer function.
Simply press the "F mode" key again (it is directly above the "End->" key between F12 and Insert on this model keyboard) and functionality will be restored.
Apr 08, 2009 | Logitech Computers & Internet
Function keyboard turned on advent QT5500
Hi
Try this my friend,
Press F12, Num Lock, and FN at the same time.
OR F12 and Num Lock/ Scroll Key.
OR Hold the Ctrl and Fn key down together and press also
the Ins(Num LK) key.
Post me whatever the result is... so we could Fixya the problem.
Feb 03, 2008 | Computers & Internet
Computers & Internet Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
